body shake, help!!
Old Jan 25, 2004 | 10:00 AM
johnno!'s Avatar
johnno!
Default body shake, help!!
hi guys, I just bought a 95 6 speed car with 73000 on it, I test drove it and loved it. On the trip home, which was very long... 2800 miles it deveolped some significant shake at highway speeds. feels very tight at sub 50 mph and it is intermittent at highway speeds. its like the whole vibrates violently. it isnt always happening, and if the road is worse so is the condition. I dont have the first clue as to whats wrong, so hopefully someone can give me somewhere to start. thanks
John
Old Jan 25, 2004 | 03:22 PM
Raysur's Avatar
Raysur
Default Re: body shake, help!! (johnno!)
Go to a tire shop and get the tires balanced then work from there. :yesnod:
Old Jan 25, 2004 | 03:27 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Sounds like you could possibly have a caliper dragging. I've felt them shake a car till I thought a wheel was fixing to fly off. Scary stuff, I'm sure you'll have it looked over real well first thing. Good luck and be careful!
Old Jan 25, 2004 | 03:55 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: body shake, help!! (Raysur)
:iagree: and I would have alignment checked as well
:seeya
:steering:
Old Jan 26, 2004 | 08:37 AM
johnno!'s Avatar
johnno!
thanks for the replys, I'll start with the wheel balance, one othe thing I noticed, it appears the engine has depevoled a bit of a shudder along with a slight power loss, so the vibration gets worse under low rpm/high load conditions IE 55-60 mph in 6th could this be the opti crapping out, or do they just fail all at once?
Thanks again,
John
Old Jan 26, 2004 | 09:59 AM
DieL's Avatar
DieL
If youre used to driving a fairly stiff car you could be experiencing thefamous c4 body shake. After i drive my olds aurors my 93 always feels like its gonna fallapart when i go over rough roads.. it just has so much flex. like a wet noodle.
Old Jan 26, 2004 | 12:35 PM
John Row's Avatar
John Row
The opti's generally go slowly. Usually, the engine starts missing at freeway speeds then the idle starts getting jumpy.
To body shake, help!!
