Ceramic Header Coatings - Your Opinion Needed!!
What company should I go with?
Anybody have any good/bad experiences to share on the topic?
Jet Hot and HPC seem to be the major players. Am I missing anybody important?
Thanks!
Edit: Make sure you get them coated inside and out :thumbs:
[Modified by C4Crazy787, 2:39 PM 1/25/2004]
The other coatings just look good. Swain tech coatings are much thicker. And that reduce's underhood temps.
The original TPIS ceramic coating turned dull after 2 months.
Warranty for new items is lifetime - used items is 3 years.
Car should be running after rebuild by end of month and I will know if the Y pipe was worth coating.
Just be sure to go with a quality coating.
[Modified by 85vet, 2:48 PM 1/25/2004]
They were installed in '97 and looked fine till last spring when I noticed some poc marking on the tubes.
That's because you never drive your car. :jester :D
Jet Hot does - I sent my headers & Y pipe for coating - they stripped & recoated inside & out.
ID85,
I guarantee you'll be blown away by the results. Hooker makes a nice header, but they outsource the coating process to some klown outfit Mexico that still doesn't seem to catch on. I'm one to take zero chances if I can. Might be kinky, but why not do the job right and re-coat the outside - the right way -while they coat the inside.
[Modified by bradvette, 10:19 AM 1/26/2004]
ID85,
I had a set of cat replacement tubes coated by Jet Hot. The pipes are 409 stainless and they were brand new. The original coating didn't last one Chicago winter. Jet Hot recoated them free of charge (I paid shipping to Jet Hot). Within a few weeks ther coating was peeling again. I have a set of headers I bought used from a waxer, they were Jet Hot coated, started peeling in the first winter I had them.
Jet Hot hasn't worked out very well for me. I'd try anyone else but them. Nobody could be worse.
Eric
Eric
We all know that problems can occur with quality products. I had a problem with AFR and if I made a statement like this I would have been jumped all over.
[Modified by 85vet, 11:24 PM 1/26/2004]
Your statement is FALSE!! I emailed Jet Hot referenceing your statement and received the following email.
We do not buy the coating from anyone
and we do not sell our coating to anyone. We do use high grade material
to insure the best quality and delivers the highest shine in the market
today. I can't speak for HPC, but I do know many other coating companies
purchase the coating just to apply it. We get a lot of calls daily from
customer who have used other coated (including HPC) that were very
dissatisfied with the coating. The coating would fail in many different
was such as rusting,peeling,discoloration, etc. Please let me assure
you, Jet Hot does produce the best metallic ceramic coating on the
market today. We work with many manufactures for this reason (example:
SLP, Dynatech, Factory five, and many more). If you have any questions,
please feel free to call or email.
This is to set the record straight on Jet Hot coatings.
[Modified by 85vet, 8:35 PM 1/30/2004]
today....
Eric
