Vibration
Old Jan 25, 2004 | 05:58 PM
AimHi's Avatar
AimHi
Default Vibration
I'm experiencing a vibration that starts at about 52-55MPH. I'm not sure if it's driveline or out of balance wheel/tires. Is there a simple way to tell? The steering wheel doesn't vibrate or wobble. I also notice a 'clunk' from the rear when making turns at slow speeds.
Are my U joints shot?
[Modified by AimHi, 6:43 PM 1/25/2004]
Old Jan 25, 2004 | 06:02 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Re: Vibration (AimHi)
That sure sounds like a distinct possibility from your description. Hopefully nothing worse than that.
Old Jan 25, 2004 | 06:03 PM
vader86's Avatar
vader86
U-joints, wheel bearings, out-of-balance, poor alignment, balljoints
it can be anything
Old Jan 25, 2004 | 06:19 PM
Corvette Kid
Default Re: Vibration (vader86)
Yes and even a rear end problem. BTW improper alignment or ball joints will NOT cause a vibration in and of themselves.
[Modified by Corvette Kid NC, 11:09 PM 1/25/2004]
Old Jan 25, 2004 | 06:23 PM
1990CORVETTE's Avatar
1990CORVETTE
your u-joints are shot,, I will bet on it... I had the same problem a couple months ago ,,, I replaced the all, and havent had a problem since :cool: :cheers:
Old Jan 25, 2004 | 06:43 PM
AimHi's Avatar
AimHi
Default Re: Vibration (1990CORVETTE)
OK, I guess I'll try the simple first; I'll get the wheels balanced then go after the U Joints. What U Joints did you use '1990 Corvette'? My vette is a 95, are the U Joints the same?
I've only owned the car a couple months so I expected to replace U Joints, hoses, etc. Anything else you guys can think of that should get immediate attention after buying a vette from a Ford fan?
Old Jan 25, 2004 | 06:56 PM
vader86's Avatar
vader86
You need Spicer Cold Forged Ujoints, ONLY Spicer joints.
Old Jan 25, 2004 | 07:13 PM
AimHi's Avatar
AimHi
Spicer only, got it. Vader86 where do you get them...online or NAPA?
To Vibration
