Holy Fluid Level Batman!
Old Jan 25, 2004 | 06:05 PM
MrWiggly's Avatar
MrWiggly
From: Sunny Seaside Seabrook Texas (a whole 'nother country)
Default Holy Fluid Level Batman!
I just checked my tranny fluid ('92 LT-1 auto) and it's a pretty pink. But... the level was far above the hash marks on the dipstick. I followed the instructions in the owners manual "to the T" for checking the level. What happens if you've got too much fluid? TIA for the help!
Old Jan 25, 2004 | 06:07 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Re: Holy Fluid Level Batman! (MrWiggly)
You could blow a seal and worse, better drain 'er down.
Old Jan 25, 2004 | 06:08 PM
bogus's Avatar
bogus
when was the fluid last checked, filled? the last person may have overfilled it.
as for damage? I have no clue...
Old Jan 25, 2004 | 06:16 PM
Corvette Kid
Default Re: Holy Fluid Level Batman! (bogus)
It could also cause cavitation of the fluid resulting in lack of lubrication to critical parts.
Old Jan 25, 2004 | 07:57 PM
CFI-EFI's Avatar
CFI-EFI
Those suckers don't make fluid. Over full and pink, says only one thing, to me. WATER ! And there are only two ways it can get in there. One would be a super ignorant lube jockey at the local grease 'n go. The other is a failed trans cooler. The interesting thing about water, is that it dissolves the bonding that holds the linings on the clutch plates. Don't ask how I know this. Good luck, and...
RACE ON!!!
Old Jan 25, 2004 | 08:27 PM
Corvette Kid
Default Re: Holy Fluid Level Batman! (CFI-EFI)
I missed that "pink" clue. Good catch!
Old Jan 26, 2004 | 02:03 PM
rhneff's Avatar
rhneff
CFI-EFI is absolutely correct, if you're fluid is actually pink it means water has gotten into the system and contaminated the fluid. He's also correct that water will cause the clutches in both the transmission and the torque converter to fail in short order - I owned a transmission shop for five years and saw firsthand the results so if this is the case DO NOT drive the car, have it towed on a flat-bed to a shop for repairs (driving it will likely result in damage not just to the clutches but to other parts of the unit that will drive the repair cost much higher). The most common cause of this problem is failure of the radiator. I don't recall specifically for the Corvette, since mine is an M6, but generally the transmission fluid runs through a metal line up to a separate section of the radiator that provides cooling and then returns to the tranny - if the radiator is damaged between those sections it will allow water to enter those lines and be carried into the transmission, and once that occurs the only "fix" is to replace all the clutches and probably the torque converter.
Old Jan 26, 2004 | 02:58 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Red is good, pink is bad.... sounds like water to me...
To Holy Fluid Level Batman!
