Need help with C Beam
Old Jan 25, 2004 | 09:05 PM
Clemson Vette's Avatar
Clemson Vette
Default Need help with C Beam
i have excessive shifter travel and you fellas told me i should tighten up my c beam bolts. my question is where are they loose at and how do i get to em? i need to take my exhaust off? how about the top ones? are there any up there? do i need to do front and rear? is this actually what's causin my shifter to leap up and down? is this beam the only thing that supports the rear of the tranny? thanks for your help men.
Stuart :lurk:
Old Jan 25, 2004 | 09:31 PM
Clemson Vette
Default Re: Need help with C Beam (Clemson Vette)
please?
Old Jan 25, 2004 | 09:34 PM
scorp508's Avatar
scorp508
I haven't been under my car in a while, but you probaly will have to drop the exhaust to get to the bolts. You'll see em' when you're under there. THere are 2 bolts at the tranny and 2 at the differential. The bolt goes up through the bottom so there is a nut on the top and the bolt head on the bottom.
Yes, the beam is the only thing that supports the rear of the tranny.
Old Jan 25, 2004 | 09:50 PM
1990CORVETTE's Avatar
1990CORVETTE
WOW I was goofing around today under mine and I tightened mine up also,,, this is the second time in 4 months....I didnt drop my exhaust,, I used a long extension for the bolt and crammed a wench up on the bolt and tightened them down,,,, really easy job,,,,,,,, 15 minutes :cheers: :yesnod:
To Need help with C Beam
