oil Change Question
Old Jan 25, 2004 | 09:51 PM
YellowC4's Avatar
YellowC4
Default oil Change Question
Why does my oil smells like gas ?? I have a 1995 LT1 with 50,000 Miles
:flag :flag
Old Jan 25, 2004 | 09:58 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Re: oil Change Question (YellowC4)
Sounds like you've got an injector leaking badly when the engine's shut off.
Old Jan 25, 2004 | 10:04 PM
C4Crazy787's Avatar
C4Crazy787
Default Re: oil Change Question (Corvette Kid NC)
:iagree: Then was your last oil change and when was the last time your oil temp got over 220* both these could also cause a gas smell in the oil.
Old Jan 25, 2004 | 11:13 PM
YellowC4's Avatar
YellowC4
Default Re: oil Change Question (C4Crazy787)
what's the best way to check for a leaking injector
Old Jan 25, 2004 | 11:45 PM
JAKE's Avatar
JAKE
There may be an easier/better way, but I had to pull the plenum, runners and fuel rails. Then lift the injectors from the intake and energize the fuel pump to visually check.
If there's an easier way, I'd sure like to know about it for the future.
Jake
Third Gear's Avatar
Third Gear
Correct me if I'm wrong. But I'd say just hook up a fuel pressure gauge to the Schrader valve (small bicycle type valve with a plastic cap on it on the fuel rail). Then get in the car and pressurize the fuel system by turning key to "ON" not "START". You should hear the fuel pump pressurize the system. Turn the car off.
Record the gauge reading at that time. Come back in a few hours and see if it has changed. If the fuel pressure has dropped considerably then you most like have a leaky injector. This is not 100% true as faulty regulator could cause a fuel pressure drop as well.
I think another method is to simply pull the rail and pressurize the fuel system with the injectors attached to see which ones leak or don't leak. I've never done this though.
Old Jan 25, 2004 | 11:48 PM
C4Crazy787's Avatar
C4Crazy787
Get a fuel pressure gage and attach it to the valve on the fuel rail, turn on the car but don't start it then turn it off, the pressure (around 40psi) should stay up for a couple hours. If it drops off quickly it could be the Injectors, the Regulator or the Check Valve at the pump. Good Luck..
Old Jan 26, 2004 | 01:57 AM
GlockLT4's Avatar
GlockLT4
I helped a buddy troubleshoot a cutlass once with the same problem. Turns out the ECM was bad and it was dumping fuel in the cylinders. Goes right past the rings and into the pan.... oil was like water :eek: .... not good. Get that taken care of fast! Don't want your oil to lose it's lubricating abilites.
Old Jan 26, 2004 | 08:50 AM
C10 JDR's Avatar
C10 JDR
Default Re: oil Change Question (GlockLT4)
Just had the same thing on my V8 Range Rover. It was the O2 sensors telling lies to the ECM which was overfuelling. New O2 sensors - sorted.
Old Jan 26, 2004 | 09:02 AM
ittlfly's Avatar
ittlfly
Default Re: oil Change Question (WickedC4)
[QUOTE]Correct me if I'm wrong. But I'd say just hook up a fuel pressure gauge to the Schrader valve (small bicycle type valve with a plastic cap on it on the fuel rail). Then get in the car and pressurize the fuel system by turning key to "ON" not "START". You should hear the fuel pump pressurize the system. Turn the car off.
Then pinch off the return and outbound rubber fuel lines located on top of the fueltank (under the rubber bladder). If the pressure still falls off, most probably leaky injectors. Also check the vacuum line from the FPR for fuel. It should be dry.
Old Jan 26, 2004 | 03:03 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
:iagree:
Old Jan 30, 2004 | 11:26 PM
YellowC4's Avatar
YellowC4
I just finished checking my injectors and they look fine there not leaking I checked them with the fuel pressure gage and I took them out and turned on the car no leaks but I noticed that I have oil in the back and front of the intake ???
thanks
To oil Change Question
