OK, I have hedman 1 5/8 long tube headers and dual exhaust, free mods, and ported plenum behind the throtle body. I have the 6-speed with 3.33 gears. From most important to least improtant, my goals are: Street performance, Road racing track performance, drag strip, auto-x. Ie, i will make the most compromises for drag strip and auto-x to keep good track and street performance.
Engine: stock, 130,000 miles
Intake: Jeb SP conversion
Cam: LT4 HOT cam kit
Do you think I'm asking too much RPM for my stock bottom end? I figure the HOT cam is good to 6000-6500rpm. How about for 20-30min sessions on the race track?
Re: 90 L98 performance combination. Your thoughts?? (Raistlin)
sounds like a mean setup. you might want to remove those hedmans though, in favor of a better header. i know a local guy who had them, and they warped & leaked like a sieve. if you looked at archives here, you might not like what you see.
I wouldnt be keeping it over 6K, but I dont think your expectations are that unreasonable. Realize that she will need more care and oil changes should be done on time with the right stuff.
Its been my experience that whatever is going bad will always break at the track.
Re: 90 L98 performance combination. Your thoughts?? (bradvette)
Yep, I've been through the header debates. My hedmans have been no problem. (I had them coated, probably helps a little)
I am thinking about switching to hooker 1 3/4" headers, but not untill I think there will be a performance gain.
My hp guess is ~350 crank hp, limited by stock 113 d-port heads.
I'm horrible about changing oil, but I do use Mobile 1 exclusively. Last time at Watkins Glen I had both the water and oil temp guages pegged. I'm planning on a radiator upgrade before April, hoping that will keep the temps in check.
If I port my 113's do you think there is any reason why it wouldn't run like a HOT cam equipped LT1? i.e. about 430 crank hp? (assuming I don't ruin the heads when I port them :D )
What do you think will be the first thing to break because of excessive RPM? rod bolts?
I assume you would like to retain bottom end torque so would advise:
-BM style intake base with AS&M LT runners
-ported #113s with larger valves, better rockers, etc
-a nice cam like ZZ-9
-enhanced ignition to support good burn over 5k RPM.
-an AFPR to match fuel to increased air flow at WOT
Go to my site and check out the table with results of mods to a L98. I believe you can get to 370chp with a modified TPI setup. If you are willing to give up a little low end torque you can likely got ~400chp with a mini or super ram intake setup. Of course up here you will likely benefit from 1 3/4" LT headers.
In what event(s) do you want to run with the 400hp+ LT1s?
:yesnod: I don't think I'd want to run a 130K mile stock bottom end for that lenght of time at that rpm. As a matter of fact I wouldn't want to run a new 2 bolt bottom end like that either.
If you think you're going to, might be time to go for a nice 4 bolt. See where your making power, even with the hot cam you might be finished generating anything but noise well before that.
Where you are going road racing in the NY area? I'd love to find a place fairly close.
Re: 90 L98 performance combination. Your thoughts?? (65Z01)
I'm actually not interested in keeping the low end tq of a long runner intake, I want to try a SBC that peaks hp around 6000rpm. (I think :) ) My thoughts are I'd push the tq peak up compared to a SuperRam 219 combination. It would be more "peaky" and I think I'd lose ET, but gain MPH on the drag strip. This is acceptable to me because I believe the higher hp would give greater acceleration above 100mph (with the narrower band of the 6-speed) This is an example of where I'd compromise 1/4 performance for road track performace.
Add in the lower cost of the converted single plane, and ease of installation and I'm willing to try. (Even though i'll give up the good looks of the TPI and SR)
I was just thinking about being able to get similar hp and tq numbers as a HOT cam LT1. The only event i'm interested in times is on a road course. I love drag racing, but will only go to the track to "see what she'll do"
Re: 90 L98 performance combination. Your thoughts?? (1MoorTym)
I would like to keep this as cheap as possible. I'd hate to tear into the bottom end, as I'd feel the need for a forged and balanced 383. Then, I'd need a bigger cam and bigger heads. Ultimately, I'd like a 427" small block, wouldn't we all? :D
I've been to Watkins Glen and am heading up there again with http://www.tracquest.com/ May 17 and 18th. I'm planning to go to 5 or 6 Driver Events with some friends of mine that drive Porsches. http://www.gtc-motorsports.com
Just a guess on my part here, but I think that if you go with Jeb's Intake or a SuperRam with non-ported D-Ports, you're going to choke the motor without some good porting and upgraded valves on your heads.
If you were going to do heads and cam along with your choice of intake (Jeb's, SR or MR), you could have a better optimized combo.
I would still be concerned with the 130K bottom end and the RPMs that you want to run.
If you wanted to keep it on the cheap, maybe you could just port your existing TPI setup and heads and get the Hot cam kit.
Right you are, on a road course you can likely select the gear with a 6-speed to keep RPMs up in the power band.
So a peaky power curve would be no problem and certainly would yield more HP.
In that case you would do better with a set of BowTie Al heads as they are beefier than the #113s and so less prone to stress cracking that big HP numbers wil bring.
I think you need angine that will run in the 6-7k RPM range which means doing the bottom end as well. You know, build the package to fit your needs.
If you want to wait till this L98 gives up, pocket port your heads along with some good valve train parts, do the cam and siamese the stock intake base. These mods willl allow you to pull strongly to 6k RPM or maybe a little more with minimal investment now.
Re: 90 L98 performance combination. Your thoughts?? (HeaderDesign.com)
jburnett is modifing Victor Jr 2975 sp manifold. that's the one i'm thinking about.
I agree the stock heads will severly choke the potential of the hot cam/sp intake combo. I'm just limited living in an apt in the city, so I won't be able to port the heads at the same time i do cam and intake. I'm guessing 350 crank hp from stock heads, a lot more from ported heads. I figure I could do this in two stages, intake/cam then later port my 113's.
Do you think ported 113's would be able to get 430hp (crank) like the LT1's?
Well, it's hard to say. LPE's port job (which includes bigger valves) has netted 450+ crank HP on a 383.
I don't think you'll get 430HP at the crank with just a port job on the 113s. You might come close with a full port/polish job with upgraded valves.
The choice of intake will also affect how much HP you're making. The MR seems to make more HP at the expense of some TQ. The SR is the opposite, and I don't have enough experience with the single plane to make a guess.
However, back to your question, I would say that you won't make 430HP on a simple port job to a d-port 113.
Re: 90 L98 performance combination. Your thoughts?? (RonRed89)
I found some information from Sallee Chevrolet website. They have upgrades for the ZZ4 engine. Option 6 has a ZZ4 with single plane intake, hot cam, and ported heads w/ larger valves. They say it makes 440hp and 437tq. http://www.sallee-chevrolet.com/Chev...V8s/PUZZ4.html
I guess I'm on the right track. Thanks for all your help.
--steve
zz4 385's use GM fastburn heads, not the l98 head.
I re-read your post on doing the intake and cam first, without doing the heads, and the logic. I think that you will find that A) you will generate additional power over stock, but B) you will then be moving the air restriction to the heads. I don't have any dyno numbers to prove out the statement I'm going to make, but it seems logical that you would likely make as much HP just doing the heads vs. all the expense and pita work doing the other two jobs?? C) you will be 90% of the way to taking the heads off anyway if you do the intake and cam. All the accessories have to be removed to do those two jobs. Why would you want to later do it all over again to get to the heads in the future??
