I just pulled the water pump...
Jan 27, 2004 | 12:10 AM
St. Jude Donor '05-'06
So....
How much more work would it take to pull the motor?
Since almost everything is disconnected. :crazy:
Jan 27, 2004 | 01:04 AM
Cruise-In II Veteran
Re: I just pulled the water pump... (Coupe89)
:lol: , you're kidding right, though it seems like half the stuff is disconnected up front.
Someone should slap the GM engineer that designed the L98 front accessory brace setup, right.
Jan 27, 2004 | 11:51 AM
St. Jude '03-'04-'05-'06-'07
Re: I just pulled the water pump... (65Z01)
:lol: :lol: :lol: :thumbs:
Jan 27, 2004 | 11:53 AM
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Re: I just pulled the water pump... (vinnies87)
:smash: :)
Jan 27, 2004 | 01:35 PM
I'd say you have quite a ways to go... Why do you want to pull the motor?
Jan 27, 2004 | 03:37 PM
Quote:
So....
Well, since you leave the accessories and such on the car when you pull it out I would guess that you haven't really made a dent in that process.
Jan 27, 2004 | 09:46 PM
Someone should slap the GM engineer that designed the L98 front accessory brace setup, right.[/QUOTE] ........................................ ................... Why stop there,find the guy that did the L83 while your at it and give him some.
Jan 27, 2004 | 11:15 PM
Re: I just pulled the water pump... (z51jeff)
Since everything seems to be apart
My roommate want me to install the Superram, cam, headers that is sitting on my bench
If I was going to install my stuff. I need to buy a few more things heads and 396.... :crazy:
Jan 28, 2004 | 05:47 AM
doooooo it! :D
Jan 28, 2004 | 10:04 PM
A lot harder than pulling the waterpump! :D :D :D
[Modified by Dixie91, 3:04 AM 1/29/2004]
Jan 28, 2004 | 11:45 PM
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
My first motor took me 6 hours to pull by myself. But it didn't have half the garbage the C4 has on it.
Is it really that hard to get to the water pump on the C4? I'm getting ready to do a cam swap (along with the pump) this weekend. Am I in for it?
Jan 29, 2004 | 12:06 AM
Re: I just pulled the water pump... (joeveto)
Same for the opti!! :crazy:
Jan 29, 2004 | 12:28 AM
Re: I just pulled the water pump... (GlockLT4)
I've had a set of problems with this motor since I owned it. I could erase all my problem this by dropping in a 383 or 396 and introduce new problems :D :crazy:
I was going to replace the transmission while I was at it :D
The only thing thats holding me back is the unknown. Never pull a motor in my life.
Im sure if I pull one motor it will not be long before my Firebird gets a new motor also :D
[Modified by Coupe89, 9:29 PM 1/28/2004]
