What method to lengthen sensor wires?
Old Jan 27, 2004 | 05:01 AM
neat's Avatar
neat
Default What method to lengthen sensor wires?
Do you guys just use crimp connections, or do you solder wires when you lengthen them for a sensor relocation?
Old Jan 27, 2004 | 05:45 AM
C10 JDR's Avatar
C10 JDR
Default Re: What method to lengthen sensor wires? (neat)
Solder, and glue-lined heat shrink.
Old Jan 27, 2004 | 09:40 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
When I moved my IAT I bought a new connector that came with about a foot of wire for each of the two leads. That way I only had to have one slice per wire instead of two.
Old Jan 27, 2004 | 09:49 AM
LD85's Avatar
LD85
Default Re: What method to lengthen sensor wires? (Corvette Kid NC)
I am a new convert,,,,Solder, solder,,,, solder,,,,, solder,,,,
Old Jan 27, 2004 | 11:08 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: What method to lengthen sensor wires? (britvette)
:iagree:
Old Jan 27, 2004 | 11:47 AM
dizwiz24's Avatar
dizwiz24
Default Re: What method to lengthen sensor wires? (vinnies87)
solder. dont ever use crimp on clamps on a sensor wire....
To What method to lengthen sensor wires?
