C4 cranks but won't start...
Old Jan 27, 2004 | 03:26 PM
lrc89's Avatar
lrc89
Default C4 cranks but won't start...
I replaced my stock thermostat with 160 today and changed the fan switch to suit. Ran the car in garage to check temp but when the engine got to 200, just cut out and now won't start.
Nothing seems to have overheated, cranks well, but won't fire.
I understand a VATS problem would prevent the car from even cranking so have ruled this out but can't find the problem.
Anyone experienced similar?
:banghead:
Old Jan 27, 2004 | 04:11 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: C4 cranks but won't start... (lrc89)
No similar experience but I responded to your thread in the General Forum.
Old Jan 27, 2004 | 05:46 PM
lrc89's Avatar
lrc89
Many thanks to the guys who were so quick to respond to my plight.
Someone asked if I could hear the fuel pump with the ignition on, before a crank. I checked and found no pump noise.
Therefore, starting from the most simple I checked the fuses to find the ECM fuse had blown.
Replaced ECM fuse and away we go. I guess water may have penetrated an electrical connection after I washed down the engine coolant and caused the fuse to blow.
I hope it was that simple.
Many thanks for your input. Corvettes Downunder :party:
Old Jan 27, 2004 | 06:18 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
:thumbs: :cool:
Old Jan 27, 2004 | 06:41 PM
86Moon's Avatar
86Moon
:hurray:
To C4 cranks but won't start...
