Fuel Injector Help...
Old Jan 27, 2004 | 04:52 PM
advcomputer's Avatar
advcomputer
Default Fuel Injector Help...
I had my mechanic look at my '86 vette because of it poor perfromance and rough running. This happened after getting some crap gas (stupid me)
Anyway - he attempted to do some injector service and it's still poor. All of the injectors are running out of spec and need to be changed.
He said the injectors are Bosch, and it's almost 1900, which seems very high to me.
Any suggestions on replacement, alternatives would be appreciated.
Thanks for the time,
Jeff Goldstein
Old Jan 27, 2004 | 05:18 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: Fuel Injector Help... (advcomputer)
Jeff,
1500-1900 bucks isnt unrealstic when you pay someone to change them out.
I was quoted 1500 8 years ago but of course I did it myself.Just wanted to see what the costs was.
One bosch injector can run as high as 120 each.Your best bet is go to an aftermarket injector and save alot more money.
Tomco Injectors are a nice stock replacement and they run about 50-60 bucks each..You can also have your injectors sent out for rebuilding unless theyre so shot they cant be fixed?
Ive also seen other people here post saying they paid about 240 or so for a set of 8 injectors from someone,but cant remember where.
Maybe it was summit racing or jegs and im not sure of the brand.
Anyways,if youre going to pay a mechanic,see if he will let you buy your own injectors to keep the cost down.Not all of them do that though.If he buys them,youre gonna pay alot of money for a pretty simple injector swap out.
Old Jan 27, 2004 | 05:20 PM
Aggravated4life
One more thing,has he done a fuel pressure test and tried to change the filter yet?I just realized your blaming it on bad gas.Id start there first.
Did he do a injector resistance test?If not,then how would he even know they were bad?
Old Jan 27, 2004 | 05:45 PM
advcomputer
Default Re: Fuel Injector Help... (Bill's86Coupe)
Yes, he has spent a lot of time doing the diagnostics, changing all of the fuel filters, etc. we tried the simple stuff like putting Techron cleaner and I ran it for 150 miles, and really no change.
--Jeff
[Modified by advcomputer, 10:58 PM 1/27/2004]
Old Jan 27, 2004 | 05:49 PM
C4-Wolf's Avatar
C4-Wolf
If you can do it yourself you can get 8 Ford Motor Sport injectors for about $220 through Summit. Accel injectors are about the same price, but a lot of people have complained about them. If you don't want to do the install at least you can save on parts.
Old Jan 27, 2004 | 06:17 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Just got some used ones on ebay and set to witchhunter.com for servicing, complete test and doc.... complete under $150.00 for injectors and tune and cleaning... :thumbs:
Old Jan 27, 2004 | 06:27 PM
CarAteMyMoney's Avatar
CarAteMyMoney
Yeah, go FMS ive heard nothing but good things about them
you can change them yourself - i'm a complete retard, and I did mine in about 3 hours without any special tools other than the hex head thingies
Old Jan 27, 2004 | 07:20 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
IMHO :lolg: You're crazy if you spend that much on injectors.
First, they are easy as hell to replace.
Second, Rich at Cruzinperformance will R&R your current, factory injectors for roughly $11.00 a piece. He'll test them, and if possible (assuming they aren't too out of whack) he'll blueprint and repair them. Then, he'll send them back to you with a link to the test results. He can get them to within 1% of each other.
Truly, replacing the injectors is a couple hour job, tops, once you know what you're doing. And it's a hell of a lot cheaper.
:cheers:
[Modified by joeveto, 6:22 PM 1/27/2004]
Old Jan 27, 2004 | 09:12 PM
JackDidley's Avatar
JackDidley
For $1500 Ill come to N.Y. and do it for you. :jester
Old Jan 27, 2004 | 09:24 PM
SPEED750's Avatar
SPEED750
Default Re: Fuel Injector Help... (Spankyellow)
Here is the hook-up!! http://www.fiveomotorsport.com/
You can get 8 new bosch injectors for $188. Plus they will answer any questions you might have. :cool:
Old Jan 27, 2004 | 10:52 PM
89C4's Avatar
89C4
How about changing out your O2 sensor?
Old Jan 28, 2004 | 12:55 AM
advcomputer
Default Re: Fuel Injector Help... (89C4)
I want to thank everyone out their for your help.
When he told me $1900, I almost lost it on him. Five-O has the ones that I need (just need to verify that I don't need the lucas injectors) for $400.00
Now i'm not a rocket scientist, but I used to build challengers and chargers 340 motors like they were nothing, so I think I can hanlde the injectors.
Can someone lead me through the process of what has to come off (fuel rail, plenumm etc) and what special tools if any are needed.
I usually have a full set of tools at my ready, nut seeing how getting divorced I can't get inito the house to get anything.
Any help would be appreciated.
Thanks again for everyones help..
--Jeff
Old Jan 28, 2004 | 01:14 PM
Wayne88's Avatar
Wayne88
My fuel injectors were dirty and led to flooding and stalling.
{88 Corvette 112K Miles]
My mechanic cleaned them; That is: He hooked up a machine to the fuel intake that fed cleaning chemicals instead of gas.
He rerouted the fuel line back into the fuel tank. He ran the car with the cleaning chemical for half hour.
I never had a problem after that.
He charged me$150
:steering:
Old Jan 28, 2004 | 02:10 PM
advcomputer
Default Re: Fuel Injector Help... (Wayne88)
Wayne88 - Thanks for that info,
I was told he did that as part of a "Fuel Injector Service" and to be honest he says it's a little better but not much.
I starting to feel as If I'm getting scammed. The car was running fine until like an idiot, I put in a bad load of gas, and within a day or so, it started running like sh^t.
Brought it to him, and he said I need a tume up, and it appears as if some of the cylinders are running lean, but lets see.
After a complete tune-up $350+, the issues were still there, so he did the Fuel Injector Service, and said it's a bit better, but none of the injectors are up to specs ( a preasure or leakage testm he performed, not sure), so then he give me a price of 1900 for the injectors from AC Delco. The injectors are Bosch or Lucas, not sure.
Several of the forum members gave me a few places to try to get 3rd part injectors. I found several places that have good prices, for rebuilt units, or they I can buy new Borg Warner units for 70 a piece.
So atleast thank to this forum, and everyone's help, I know I have alternatives.
Bit now I'm wondering what the issue is. He changed the fuel filters during the tune up and told me they were totally clogged.
It just does not make sense to me, that one bad tank of gas can cause almost 2000 worth of damage.
--Jeff
Old Jan 28, 2004 | 02:18 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Last fall I bought a set of injectors on ebay from five0 motorsports. $179 delivered. It cost me $275 to have them installed. They work fine.
Dan
Old Jan 28, 2004 | 02:43 PM
Wayne88's Avatar
Wayne88
Default Re: Fuel Injector Help... (brdd)
I can see your mechanic changing the fuel filter and cleaning the injectors, but needing a tune-up has no direct relationship to a 'bad' tank of gas. Needing a tune-up is a gradual thing, you feel it coming on.
On the upside: when you get this problem solved, your car will be freshly tuned.
I will add [And I don't think this is your problem, but] My vette was lacking power and spongy acceloration. My mechanic said the catalytic converter is partially blocked, I had him change it--Solved the problem.
The point is- you never know.
:chevy
Old Jan 28, 2004 | 02:53 PM
TA's Avatar
TA
There's a guy on Ebay that regularly sells FMS 24# injectors for $150 :yesnod:
Thats where I got mine
To Fuel Injector Help...
