(Technical Assistance Needed)
Old Jan 28, 2004 | 06:39 PM
autotech's Avatar
autotech
Default (Technical Assistance Needed)
(88 C4 TPI) My engine is using oil on a fresh rebuild. Exhaust is soaked. Oil is coming up through the EGR system. We used the old pistons, hoaned and re-ringed. I resealed the intake, did not help. I dont show any blow-by, PCV system is clean as a pin. I have the engine scattered now and the pistons dont show to be leaking by, and the bore is not too far out. How's it getting in there? If not the intake or rings....Head gaskets look to be sealing well. I'm lost at the moment. We are going to bore and install new pistons but I am sceptical...
Old Jan 28, 2004 | 07:34 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: (Technical Assistance Needed) (autotech)
If there is oil, not carbon, getting into the EGR system there must be an oil leak into the intake base, right.
Old Jan 28, 2004 | 07:42 PM
autotech's Avatar
autotech
Default Re: (Technical Assistance Needed) (65Z01)
There is carbon in there also....
Old Jan 28, 2004 | 07:49 PM
96BLKTN's Avatar
96BLKTN
What about the heads. Did you look at the valve seals? Just a thought...
Old Jan 28, 2004 | 07:50 PM
autotech's Avatar
autotech
I did look for cracks in the intake. Maybe I need to look again...
Old Jan 28, 2004 | 07:57 PM
autotech's Avatar
autotech
Its using about a quart in 500 miles. We reworked the heads. All new...
Old Jan 29, 2004 | 01:44 PM
bully-3's Avatar
bully-3
i have seen this problem before on the forum. they said it was so bad it was running out of the throttle body, but all i can remember is that it had to do with the egr system. i just can not remember the exact part that was bad.
it could still be a blowby problem though.
Old Jan 29, 2004 | 06:56 PM
ittlfly's Avatar
ittlfly
:iagree: I'd be looking real hard at that intake. Maybe you can pick up a spare and try it instead.
Old Jan 29, 2004 | 08:58 PM
BBA's Avatar
BBA
Honed and re-ringed with the original pistons?
You probably have pistons fitting too loose to seal. Have you mic'd the bore and the pistons? If so, what are the measurements?
Old Jan 29, 2004 | 09:40 PM
autotech's Avatar
autotech
Default Re: (Technical Assistance Needed) (BBA)
My machinist checked them. I have it back down there now to be bored - Installing TRW flat-tops. If the problem was there. It will be no more... :thumbs:
To (Technical Assistance Needed)
