Good Nitrous Setup???
Old Jan 29, 2004 | 08:32 PM
autotech's Avatar
autotech
Default Good Nitrous Setup???
How much is a good Nitrous setup for a C4? Just a good one, not extravegant... :thumbs:
Old Jan 29, 2004 | 08:56 PM
ANTI VENOM's Avatar
ANTI VENOM
Default Re: Good Nitrous Setup??? (autotech)
New, probably just under $600 with NO FRILLS. There may be cheaper kits now, but I haven't priced them in quite awhile. Do a search and you are sure to find tons of info. Good luck!!!
Old Jan 29, 2004 | 09:02 PM
autotech's Avatar
autotech
Default Re: Good Nitrous Setup??? (ANTI VENOM)
Zex's looks pretty good... :thumbs:
Old Jan 30, 2004 | 06:07 AM
84 Blue Thunder's Avatar
84 Blue Thunder
You will be looking at about $600 for the kit but the kits only come with the minimum pieces to make it work. BUT to make it work PROPERLY you will need to buy additional components (purge system, bottle heater, bottle gauge, overpressure blow off for the bottle) The kits that you can buy (atleast mine) do not include these items. By the time I was done with my system I had $1000 invested.
Mike
Old Jan 30, 2004 | 07:04 PM
red-y's Avatar
red-y
Default Re: Good Nitrous Setup??? (84 Blue Thunder)
I agree with the fact that it costs more than $600. That is starters :skep:
Do it right or wait until you can. If you blow your engine it will be $5000.
Plan on $1000 o $1300 :steering:
Old Jan 30, 2004 | 07:52 PM
ANTI VENOM's Avatar
ANTI VENOM
Default Re: Good Nitrous Setup??? (red-y)
I personally don't think that a heater and a purge valve are necessary. The gauge is nice to have, but the kit still works without it. Even a vent tube isn't necessary in my opinion, but a worthwhile piece, my kit came with one. If I was going to spend extra money, it would be in an ignition system and possibly a low fuel pressure cut off. (hobbs switch,= cheap) If consistency is key, then yes you will need some other features, but to run on the street, a basic kit will work. Yes I have other safety features, but with modest amounts of nitrous, a good understanding of how it works, and a solid engine, you should be fine. Good luck!
Old Jan 31, 2004 | 07:07 AM
84 Blue Thunder
The bottle pressure is the most important part of making a nitrous system work correctly. Without the bottle heater to rasie the pressure in the bottle and the gauge to monitor it....your wasting your time and money. If you plan on doing any racing at a drag strip you may need the blow off and vent tube or they may not let you race.
I agree with you on the purge solenoid and blow off, but not the bottle heater and gauge. Will it work with out these items....YES, but properly....NO :cheers:
Look at it this way.....A "just filled" bottle will be at approxitamately 900 psi, after each shot, the pressure will continue to decrease. The bottle heater is used to heat the liquid nitrous in the bottle so the pressure in the bottle goes back up. Most systems need a minimum of 900 psi to work properly.
Mike
[Modified by 84 Blue Thunder, 12:34 PM 1/31/2004]
Old Jan 31, 2004 | 10:36 AM
ANTI VENOM's Avatar
ANTI VENOM
The way I see it, 90% of the kits out there are probably not tuned to the specific vehicle and therefore the kit is usually calibrated to run rich as a safety margin from the factory, so those kits are not being run "properly". My point is, that on the street, I don't run my bottle heater (or purge) every time I get in my car. If you decide on a whim that you are going to run the nitrous, that heater won't help you in time. So who cares what your gauge says, when it's time to go, I flip it on and it gives me what it gives me. I was making close to 200 exta rwhp with my kit in perfect conditions, and if I run it with the bottle pressure alittle low and only get an extra 100 hp out of it, so be it! That being said, bracket racing is a hole different bag. If you are going to be consistent with nitrous, you probably will need a heater (if rules allow) and a purge and a gauge, and a blow of tube that expells the gas outside of the vehicle unless the bottle is mounted outside of the cabin. (check rules on that as well) You have to decide what you want to get out of your nitrous use and that should tell you how to spend your dough. Good luck!
Old Jan 31, 2004 | 10:47 AM
ANTI VENOM's Avatar
ANTI VENOM
I just looked up the rules for the NHRA ET Pro class (12.00 sec and slower) and external heating of nitrous bottles is prohibited.
Old Feb 2, 2004 | 03:52 PM
neat's Avatar
neat
10 lb bottle off E-bay- $50
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2457227470
Line from your local hose supply store- $50
Shark nozzle off ebay- $15
http://cgi.ebay.com/ws/eBayISAPI.dll...category=32094
Jets- $25 from any NOS supplier
Activation switch- $3 at radio shack
Window switch- $50 off ebay
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2457634039
Bottle heater- $50 off ebay
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2457786516
That's $243 dollars.
Old Feb 2, 2004 | 07:09 PM
ANTI VENOM's Avatar
ANTI VENOM
Default Re: Good Nitrous Setup??? (neat)
Now that is being thrifty. Shows what a little research can do for ya. A window switch for $50.oo is also a worthwhile piece. Great job!
Old Feb 2, 2004 | 09:15 PM
neat's Avatar
neat
Thanks. It took me all of 10 minutes to find that stuff too, lol.
Old Feb 10, 2004 | 11:56 PM
vettgod's Avatar
vettgod
that is a good deal , but if you click on the links now you can see that the parts went for a little more then what was listed ....but still cheaper then buying a new kit ....where do you buy the instruction sheet that you dont read until its too late ???? lol ... :lol:
To Good Nitrous Setup???
