Plug In for Knock Sensor Broke! HELP
Old Jan 30, 2004 | 08:40 PM
ROCKY85's Avatar
ROCKY85
Default Plug In for Knock Sensor Broke! HELP
When replacing the starter I hit the electrical plugin for the knock sensor, the brittle plastic housing crumbled and I can't get to stay attached, is there a replacement available? If so where and an idea of the cost?
Rocky :flag :cuss
Old Jan 30, 2004 | 08:54 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: Plug In for Knock Sensor Broke! HELP (ROCKY85)
Which side is it on, the sensor or the wiring harness?
http://www.rockauto.com has a pretty complete parts listing, adn usually has the plug pigtails available for sale for various sensors. Knock sensor would be under category of emissions i think...
Old Jan 30, 2004 | 08:59 PM
ROCKY85's Avatar
ROCKY85
It's on the sensor end.
Rocky
Old Jan 30, 2004 | 09:13 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Rocky
:smash: :smash: :smash:
I think your looking for a sensor now :eek:
Old Jan 30, 2004 | 09:14 PM
ROCKY85's Avatar
ROCKY85
My mistake harness side
Rocky :flag
Old Jan 30, 2004 | 09:42 PM
86Moon's Avatar
86Moon
Many parts houses have these kind of parts available. I'd bet the dealer does too, maybe even in stock. I broke the "pin" off mine and got it from an independent parts house that does machine work. Had to get it in a box of five I think but it was cheap and they got it in the next day so it was local.
There are "special" tools required to use a lot of this stuff, but if you use your imagination you can get around that. Go for it. :smash: :cheers:
Old Jan 31, 2004 | 01:13 PM
SkipI's Avatar
SkipI
I just had to replace mine.......
http://www.ecklers.com/product.asp?p...3GU799QA1587G2
Old Jan 31, 2004 | 09:11 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Plug In for Knock Sensor Broke! HELP (SkipI)
:iagree: :thumbs:
Old Jan 31, 2004 | 09:31 PM
SunCr's Avatar
SunCr
I found the connector at PEP Boys - As I remember, it's the same as the aux fan switch.
Old Jan 31, 2004 | 09:32 PM
SunCr's Avatar
SunCr
I found the connector at PEP Boys (outrageously priced at about 10 bucks) - As I remember, it's the same as the aux fan switch.
Old Feb 1, 2004 | 10:28 AM
ROCKY85's Avatar
ROCKY85
Thanks for the help and link.
Rocky85
To Plug In for Knock Sensor Broke! HELP
