Rear spring spacer question
Old Jan 31, 2004 | 12:45 PM
Bob Thomas's Avatar
Bob Thomas
Default Rear spring spacer question
Anyone know the right combination of rear spring spacers for a 89 Z51 coupe? It is listed in the factory shop manual. My car has been apart so long I can't find my notes on their order. But I finally have a new spring and want to put in this weekend. Thanks. :)
Old Jan 31, 2004 | 01:21 PM
Guest
Guest
Posts: n/a
Default Re: Rear spring spacer question (Bob Thomas)
Hey, i "belive" it is 2 above and two below, there will also be the paper type adhesive ones that may or may not be still attached to the housing,,,,either way tighten them evenly and make sure it goes together smoothly,,,,if it is off center it can crack the lower spring bracket, i learned the hard way :lol: goodluck :cheers:
Old Jan 31, 2004 | 09:38 PM
h rocks's Avatar
h rocks
If you want to modestly lower the rear (and more effectively than long bolts)just put all spacers under the spring. It will give you whatever the total thickness of them happens to be. ~1.250"? Make sure you get it aligned after you put it all back together regardless of any match marks etc. you may have made. Those cam bolts are notorious for moving anyway.
To Rear spring spacer question
