anyone have/fix a code 42
Old Jan 31, 2004 | 04:32 PM
SBNova's Avatar
SBNova
Default anyone have/fix a code 42
I am getting a code 42 (spark control code) after swapping to a 165 ecm, from my 6870. Has anyone had this code, or can anyone point me in a direction of diagnosing the problem??? Thanks
Old Jan 31, 2004 | 04:59 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: anyone have/fix a code 42 (SBNova)
The first step is to see if the connector in the tan/blk wire is in tact.
If you can access the ECM pins you can verify that:
-the By-Pass voltage is non-zero: ECM pin D5 & dist pin B
-the EST voltage is varying: ECM pin D4 & dist pin D
-the Reference voltage: on ECM pin B5 is the same as at dist pin C
These tests should isolate the problem; likely a connection.
Old Jan 31, 2004 | 09:07 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: anyone have/fix a code 42 (65Z01)
:iagree: :thumbs: had a bad connector on mine....
Old Jan 31, 2004 | 11:35 PM
SBNova's Avatar
SBNova
hey thaks for the tips! I will check them out monday night when I get a chance.
Old Feb 2, 2004 | 02:15 PM
Damien89's Avatar
Damien89
How did it go did you fix code 42? I also have it.
To anyone have/fix a code 42
