I bought the felpro set of gaskets for the 90 upper intake runner set. As you can see, on the lower portion, the smaller more oval looking hole doesnt match up. Everything else fits perfectly. And the weird thing is that this gasket exactly matches the one I took off the car, so it had that same problem all along. Does it matter?? hopefully this pic turns out..
Re: Need Gasket help before I continue. (Hooked on Vettes)
I agree with "Hooked" as those runner gaskets are very similiar and difficult to determine exactly where they go. Make sure you fit the gaskets with all the runners before you install the first gasket. Do this on a bench and you will get it right.
