cam choice
Old Jan 31, 2004 | 08:56 PM
Vett-eight-nine's Avatar
Vett-eight-nine
Default cam choice
What kind of cams are we installing? I have a stock L98 right now.
Would any cam change necessitate mods to the chip? What kind? Is a cam worth the effort in performance gains?
Old Jan 31, 2004 | 10:08 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Re: cam choice (Vett-eight-nine)
I'll let others advise you on cam choice for an L98 and programming. But to answer your other question, yes, the right cam is definitely worth the effort!
Old Jan 31, 2004 | 10:13 PM
vader86's Avatar
vader86
You need a long term plan before just changing a cam, you need to decide on whether you want to keep the TPI intake or are willing to switch to Superram. If you have a 6speed, you could also consider the Miniram.
Any cam thats much different from stock requires a PROM reprogram.
A cam is worth the effort, if you have done your research and put together the right combination to go with it.
Old Jan 31, 2004 | 10:27 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default Re: cam choice (vader86)
:iagree: A cam is a necessity, but it will never reach it's full potential unless you also match heads, intake, and exhaust to work with it.
To cam choice
