I have a 90 coupe with 10k original. I am thinking about installing
flowmasters. Anyone have flowmasters installed. Is the tune too loud ?
I have a 92 Z28 with an L98 and the flowmasters give it a nice
throaty sound.
Also, I am thinking about installling the y pipe with crossover tube to eliminate the rpm reasonance. Has anyone installed this hardware ?
Does it perform as advertised ?
Should I only install one or the other ?
Thanks in advance.
Ken
(Cupertino - just west of San Jose)
:seeya
[Modified by 90coupewithlowmiles, 4:42 PM 2/1/2004]
Re: Flowmaster and Y-pipe with crossover tube (90coupewithlowmiles)
The flowmaster system for the L98 C4's use 3 chamber mufflers, so the exhaust isn't real loud unless your getting on it. The flowmaster on your Z28 is probably a 2 chamber and quite a bit louder. I had a 2 chamber on my LT1 T/A and it was quite a bit louder, but the difference was more defined at lower throttle imputs than at wot.
I don't know about the crossover tube, if it would help.
The FlowMasters are well known for their loudness & resonance on a C4; don't know if the cross-over pipe will reduce resonance but you could try it both ways. Anyway, with stock headers, front Y and cat it be somewat subdued.
I have the TPIS FlowMaster cat-back behind stock headers, custom front Y and RT hi-flow cat. There is some resonance in the 1,200-1,800rpm range at light throttle. However she does roar when you go to WOT and I just love it.
Re: Flowmaster and Y-pipe with crossover tube (65Z01)
Thanks for the input. The advertisement in Eckler's indicates
that the Y with cross tube will reduce the resonance. Just thought
I would put out a feeler. I will call Eckler's tech department to
verify whether the Y with cross and flowmasters is a good performing
combo.
I used the y-pipe with crossover with Dynomax mufflers. Didn't notice much difference. I had a muffler fall of my 89 due to a rusted y-pipe. The car without the muffler was not very much louder. I still had the two precats up front and stock single in the middle. You could probably go with muffler elims and still not be loud.
It is funny you ask...I just did that set up....I dont like it at all way to much resonance at low speed. :crazy: If it wasnt for that it would be nice. But I do a lot of L.A. city driving (stop and go) so it SUCKS!
I had the guy weld some sweet tips on the back. But I would like to sell them and get something else. Talking about a waste of money :cry
I never heard a vett without the rear Y cross pipe so I could'nt tell you how much it helped on the resonance. But in my opinion, I did'nt help at all.
I have a 90 with the flowmasters. Between 1500-2000 rpms (or around 70 mph) the resonance is deafening. But when it gets to be too much I just shift into 5th and it all goes away. You can not hear the person next to you unless they are yelling. I am not sure if the crossover pipe will help, but the flowmasters are loud at cruising speed in 6th gear.
Definitely a good "seat of the pants" improvement. Not sure how many horses gained.
Re: Flowmaster and Y-pipe with crossover tube (1SLO POK)
Thanks for the valuable input. My main objective was to eliminate the
resonance with the stock Y. Eckler's advertises the Y with cross-over
to eliminate the resonance. From the replies to this point I should probably
just leave the stock Y as is.
Of course I have another option which is to leave my 90 L98 in the
garage and take out the 90 Zr-1 (4k original) more often......lol
