Old Feb 20, 2015, 01:52 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Remove and replace intake manifold gaskets/seal
Old Jul 29, 2010 | 12:45 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Originally Posted by JAKE
GEEZZZ! You went back to 2004 to dig this up?? What's up with THAT! Motivation?? Is it because I questioned your LSA claim in another thread?? Seems that way to me.
Try again. I just didn't notice the dates on the post(s).
Some other nimrod pulled it up.
My motivation is the desire to use a sealer on my runner gaskets. But, because feedback is strong enough AGAINST the use of silicone sealers on an intake, it seemed worth posting. I'm sure silicone works for awhile, but does it work for 5 or 10 yrs?
Old Jul 29, 2010 | 06:44 PM
tblt44's Avatar
tblt44
I'm the nimrod,I guess theres something wrong with me wanting to do reserch,so when I do my intake it doesn't leak.Well it's six years old so how can it work now.I guess I better use a new thread that will work better.
So what ever you and the other guy are into it about leave me out and also the name calling please.
If you look I put the popcorn thing,just so I could go back and find it.
Old Nov 1, 2011 | 04:27 PM
STL94LT1's Avatar
STL94LT1
Originally Posted by killlerkc
What file.... Oh file...... Where did you file???
Let us know kc
"Jake" is no longer with us.
Old Nov 2, 2011 | 10:13 AM
rickneworleansla's Avatar
rickneworleansla
Old Mar 10, 2012 | 04:22 PM
93LT1's Avatar
93LT1
Default Bless his soul
What a great write up... thank you Jake.
Old Mar 11, 2012 | 01:18 AM
Cliff Harris's Avatar
Cliff Harris
I placed the thin layer around the water ports ONLY and let it setup/glue to the heads overnight.
This is what I did because when I took the manifold off the original gaskets were saturated with coolant around the water ports and I didn't want another leak in that area in the future.
The gasket set I bought (I think it was Fel-Pro) did not come with end gaskets. They supplied a small tube of silicone sealer, which I used.
Old Aug 25, 2012 | 11:06 PM
c4-VetteLuv's Avatar
c4-VetteLuv
After extensive reading and research... by far this is THE BEST - BAR NONE most comprehensive directions I've seen. !
Old Feb 18, 2013 | 06:35 PM
Gobygred's Avatar
Gobygred
Is it necessary to drain coolant to R & R an Lt1 intake manifold? I've got conflicting info. The FSM says drain coolant. Thanks!
Old Feb 18, 2013 | 08:45 PM
Rod Schneider's Avatar
Rod Schneider
Yes, you need to drain the coolant or it will dump into the engine when you break the seal on the intake manifold. EDIT: DOH! I was thinking L98..... Never mind.
Old Feb 18, 2013 | 08:50 PM
Gobygred's Avatar
Gobygred
Thank you!!!
Old Feb 18, 2013 | 09:39 PM
aboatguy's Avatar
aboatguy
Not on an LT1 its a dry intake
No intake coolant ports so no way to leak coolant.
Old Feb 18, 2013 | 09:40 PM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
There is no coolant running through an LT1/4 intake manifold.
If the throttle body coolant line is still in place, you would need to remove a little coolant.
If the throttle body coolant line has been bypassed, no need to remove any coolant.
Old Feb 18, 2013 | 09:44 PM
  #33
Gobygred's Avatar
Gobygred
Makes perfect sense. Thank you so much!
