Cat gutting - stupid questions
Old Feb 2, 2004 | 11:25 AM
95VROOM's Avatar
95VROOM
Default Cat gutting - stupid questions
Sorry, but my search feature is down.
Can I assume that when you gut your cats to reduce back pressure you are also rendering the car non-street legal? Georgia has yearly emissions tests.
Any feelings for how many miles of normal (non-track) driving it takes to get the cats to a point where they are abnormally restrictive?
Old Feb 2, 2004 | 12:35 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: Cat gutting - stupid questions (95VROOM)
Hmm I dont listen to all the talk about back pressure. Im sure others with flame me for that. If you gut your cats you will not pass state inspection.
Do this:
Get bolt-on straight pipes inplace of the cats. Be sure to include the O2 bung. Cost 100$ at the most. Then when inspection comes put the cats back on. This is a good mod. The cats were really holding back my '92. Probably the easiest/cheapest thing I ever did to it.
:chevy
Old Feb 2, 2004 | 12:49 PM
scorp508's Avatar
scorp508
Default Re: Cat gutting - stupid questions (VictorRussell'92)
This is unfounded.
You can easily pass emissions tests if the car is in proper running order. You "might" not pass a visual if they actually crawl under the car to look, but if you retain the stock bodies of the cats and just put a piece of straight pipe inside of them nobody will ever know. ;)
Old Feb 2, 2004 | 01:03 PM
rick lambert's Avatar
rick lambert
Default Re: Cat gutting - stupid questions (scorp508)
You'll know when your cats are going bad! Yeah, I've taken a cat off and knocked out the material, put it back on and never had a problem with passing emissions :D just keep it well tuned and :steering:
Old Feb 2, 2004 | 11:10 PM
rhneff's Avatar
rhneff
Some of the posted replies may be incorrect depending on the year of your car and the method your state uses for testing. I'm assuming from your alias that yours is a 95, which if memory serves was still OBD I. Mine is a 96 and is OBD II, has an O2 sensor ahead of the cat and one behind, on each side, and if the cats are gutted you have to use a gadget to bypass those behind the cats or the computer will set codes, the SES light will stay on, and at least in Texas the car won't pass the emissions test. On OBD II cars, Texas doesn't use the "sniffer" just an electronic scan so even a finely tuned car won't pass if the sensors aren't all working. So make sure you know what kind of test your state does - it gets expensive if you end up having to replace those cats to renew your tags, and don't ask how I know that 'cause the memory is still painful.
To Cat gutting - stupid questions
