Brake Booster cracked.
Old Feb 2, 2004 | 05:59 PM
jimmyd's Avatar
jimmyd
Default Brake Booster cracked.
well I found my brake problem, maybe I can get back to my fuel pressure leak.
Old Feb 2, 2004 | 06:02 PM
MSR's Avatar
MSR
Default Re: Brake Booster cracked. (jimmyd)
my '96 did that in the exact same place. any chance you have longtube headers? i noticed the crack was right where the rear cylinder's tube snakes close to the booster.
-michael
Old Feb 2, 2004 | 06:35 PM
jimmyd's Avatar
jimmyd
Default Re: Brake Booster cracked. (MSR)
-michael
yea I have long tubes, (TPIS) I thought about the heat also. Im making a heat shield tomorrow before the new booster goes back on.
Old Feb 2, 2004 | 07:52 PM
okinawa86vette's Avatar
okinawa86vette
I didn't think that headers would do that. I'm going to have to make a heat shield or put some sort of heat resistant wrap on the booster when I get my longtubes.
I just replaced my booster not 1000 miles ago, and I don't want to have to do it again.
Chris
Old Feb 3, 2004 | 04:59 AM
86PACER's Avatar
86PACER
Default Re: Brake Booster cracked. (okinawa86vette)
I have a metal brake booster in my 86. :D
Old Feb 3, 2004 | 10:08 AM
okinawa86vette
Default Re: Brake Booster cracked. (86PACER)
Where did you get that? What brand? C'mon now, details.....
Old Feb 3, 2004 | 01:45 PM
86PACER's Avatar
86PACER
I do not remember the brand. I got this one at a local Advance Auto Parts store. It even comes with a warranty. You should be able to get one at a local Pep Boys, Napa, or other parts stores locally. The cost was $90. I have had it for about 18 months and have had no problmes with it. :D
Old Feb 3, 2004 | 01:54 PM
Z06_BluByU's Avatar
Z06_BluByU
the metal booster is the ZR1 booster (Im pretty sure). They are interchangable... (and you will need to verify this!).
Old Feb 3, 2004 | 01:59 PM
okinawa86vette
Cool. I just replaced mine not long ago, but I'll keep in mind there's an upgrade for next time.
Chris
Old Feb 3, 2004 | 04:23 PM
8835thL98's Avatar
8835thL98
mine was busted, somehow.... :skep:
Old Feb 3, 2004 | 06:20 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Jimmy, you can get the metal ones at Auto Zone or Pep boys... don't know about Napa... for your year... :thumbs:
Old Feb 4, 2004 | 01:19 AM
jimmyd's Avatar
jimmyd
Default Re: Brake Booster cracked. (vinnies87)
Thanks, The only place that had one in stock with a lifetime waranity was Advance, It isn,t metal but it looked ok. I made a small heat shield out of alum. The day mine cracked or broke it was 12 degres out side, I just started the car to keep the battery up. So mine was just old (88) plus the extreme temp. differance.
Ain't life fun.......
Old Feb 4, 2004 | 01:35 PM
JAKE's Avatar
JAKE
Exactly the same problem I had last week when mine cracked too. I put up a separate post about it too, but no photo.
I bought mine from O'Reilly's (plastic too) with a lifetime warranty: $111.95 + tax, exchange ($25.00 core charge which was refundable.)
Not a big deal changing it out except getting to one of the nuts from under the dash.
I intend to add a heat shield too (long tube TPIS headers) just in case heat is the cause.
Jake
Old Feb 4, 2004 | 03:41 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: Brake Booster cracked. (JAKE)
Just a new thought,can a plastic booster that cracked be repaired?Can you use an plastic epoxy repair of some kind?Or is the internal vacuum/pressures too much that it would blow/crack the repair back apart?Ive never seen one cracked up close so Im just wondering.I know with the brake system it should be fixed not "repaired" due to safety concerns but just curious.
Old Feb 4, 2004 | 04:43 PM
bill mcdonald's Avatar
bill mcdonald
Default Re: Brake Booster cracked. (Bill's86Coupe)
I had long tubes and my cracked in the same spot. I got one at autozone. I took it back cause the rod was bugging me, they gave me a metal one.
Old Feb 4, 2004 | 05:11 PM
MSR's Avatar
MSR
repairing crack:
for liability reasons, the answer is obviously NO.
i have a new booster but have not yet installed it. in the meantime i liberally applied a tube of RTV, completely covering the crack, and let it dry. this was over a month ago, and it has held fine since then.
-michael
Old Feb 5, 2004 | 12:43 AM
jimmyd's Avatar
jimmyd
here is a pict of the heat shield if anyone is interested.
To Brake Booster cracked.
Old Feb 5, 2004 | 01:22 AM
xs650's Avatar
xs650
I think you posted the picture with the Klingon cloaking shield on by mistake.
Old Feb 5, 2004 | 01:29 AM
xs650's Avatar
xs650
Don't do this at home kids.....
It's a vacuum resevoir so the crack is in compression with very low stress.
If one were to clean and abrade the area around the crack and stick on a couple layers of glass cloth with the right stuff (epoxy, most likely ) it could end up stronger than new where it cracked.
That wouldn't do anything for the fact that the plastic resevoir is old and heat abused. If you put a heat shield on it, it might give you several more years service, or not.
The decision is yours. Your repair will be less reliable than a new resevoir, and probably more reliable than the resevoir you were driving with the last couple of years before it cracked.
What the worst thing that happens if it cracks again? Can you stop the car fast enough with no vacuum boost? Depends on the driver and the car.
[Modified by xs650, 10:31 PM 2/4/2004]
Old Feb 5, 2004 | 04:34 AM
bill mcdonald
Default Re: Brake Booster cracked. (xs650)
actually, I think it is that piece of metal, uhh the smaller metal then what I was expecting in the pic over the number 7 header primary.
