Should you replace HEI module ?
Old Feb 2, 2004 | 10:03 PM
Xssesive's Avatar
Xssesive
Default Should you replace HEI module ?
I recently purchased an 86 Corvette with a slightly modified motor(AFR Heads and Accel Super Ram Plenum and Runners). I bought a new dist. cap and bug for it as the other looked stock and very old. Was wondering if replacing the HEI module with something like the MSD unit is of any benefit or a waste of money. Thanks for any info
Old Feb 3, 2004 | 11:31 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Should you replace HEI module ? (Xssesive)
Your prob just fine with stock....use your money wisely elsewhere... :thumbs:
Old Feb 3, 2004 | 11:33 AM
scorp508's Avatar
scorp508
Default Re: Should you replace HEI module ? (vinnies87)
Your superram allows your car to breath at a much higher RPM level than the stock TPI ever would. While you have not quite hit the edge of the stock HEI system going to an MSD HEI in-cap coil may not be a bad idea for a littel insurance. If you do go this route be sure to also get the low-reisistance HEI bushing that MSD offers also.
Old Feb 3, 2004 | 07:14 PM
Xssesive's Avatar
Xssesive
Default Re: Should you replace HEI module ? (scorp508)
Thanks for your replys.
Old Feb 4, 2004 | 01:30 PM
JAKE's Avatar
JAKE
I've read a caution about using the low resistance bushing, that it can cause problems with the digital tach.
I've never run one, (so I don't have any personal experience) but one of the catalogs cautions against using it.
GM and Accel also specify only a certain coil be used too; depending in the color of the wires on the pickup coil.
Jake
Old Feb 4, 2004 | 01:32 PM
scorp508's Avatar
scorp508
Default Re: Should you replace HEI module ? (JAKE)
No problem with mine. :)
Doesn't matter in the vette from what I've seen. The wires on my MSD are white and red and it works great.
Old Feb 5, 2004 | 10:46 AM
dlmeyers's Avatar
dlmeyers
Benefit vs waste of money.
Basically, it's a switch. If it continues to perform as designed, the pistons will do their thing. Some folks carry a spare for no start conditions. I seriously doubt you will see any performance gain. Determining when a solid state electrical component fails is a task I've left to probability. I'd spend the money on a fuel pressure test gauge thereby insuring reliable fuel system operation for several years. Buying a special tool generally means you'll never use the darn thing.
Enjoy the ride.
dlmeyers 90 coupe zf6 3 speed shocks
Old Feb 5, 2004 | 11:07 AM
scorp508's Avatar
scorp508
Default Re: Should you replace HEI module ? (dlmeyers)
I find that to be true for spare parts too!
Old Feb 5, 2004 | 11:56 AM
2manyfuncars's Avatar
2manyfuncars
I ran an MSD coil and a bushing in my 90 - for about a week. The coil basically fried in no time. Stock coil back in and no problem. Put stock bushing back in too, but I don't know if that had any negative effect or not. In theory the stock bushing is just extra voltage drop you don't need.
I replaced a module as well, but never noticed any difference. Now I have a spare...
Good luck
Old Feb 5, 2004 | 12:00 PM
scorp508's Avatar
scorp508
Default Re: Should you replace HEI module ? (2manyfuncars)
Well that sucks. I've got a few thousand miles on my MSD parts without trouble "so far" after previously burning up two Accel supercoils in a matter of weeks.
Old Feb 6, 2004 | 04:52 PM
CAJUN C4's Avatar
CAJUN C4
What really helped mine was installing a Holley Super Pick up module, Petronix HP Coil, Low Resistance MSD Bushing & MSD Super Conductor Wires.
Old Feb 8, 2004 | 06:54 PM
JAKE's Avatar
JAKE
The GM Shop Manual for the 86 specifically addresses the ignition coil/pickup coil wire color issue and so does Accel in their ads. I posted the exact quote from the Shop Manual a few weeks ago when this same question came up.
It's also comes up from time to time on other forums as well. There must be a reason that the pickup coil and the igniton coil must be properly matched; some have suggested it's polarity issue.
Advertisements for the low resistance bushing also caution that it may cause tach manfunctions; that certain tachs need the high resistance to function properly.
Jake
To Should you replace HEI module ?
