half shaft u-joint question
Feb 2, 2004 | 11:03 PM
I am getting ready to replace the half-shaft u-joints...
Curious... but what is a good u-joing retainer and bolt?
Thanks! :thumbs:
Feb 2, 2004 | 11:09 PM
St. Jude '03-'04-'05-'06-'07
Re: half shaft u-joint question (bogus)
Vader had a great write up on this topic... maybe he'll join in.. :thumbs:
Feb 2, 2004 | 11:43 PM
:bb
[Modified by bradvette, 12:24 AM 2/3/2004]
Feb 3, 2004 | 12:00 AM
I just re-used the originals
Of course I drive pretty sane :jester
Feb 3, 2004 | 08:27 AM
Re: half shaft u-joint question (vinnies87)
I would look for it... but that may be a waste of good time...
Thanks! Perhaps the bump will get his attention!
Feb 3, 2004 | 10:39 AM
The power is transfered between the u joint cap and the yoke. The strap merely keeps the cap engaged, properly, with the yoke. Unless you are making a god-awful amount of power or have worn yokes, the stock straps are more than sufficient.
RACE ON!!!
Feb 3, 2004 | 10:40 AM
Cruise-In I Veteran
Cruise-In II Veteran
Not sure there is much in the aftermartket for the straps and bolts. I just use the stock ones personally.
Feb 3, 2004 | 11:14 AM
Feb 3, 2004 | 11:25 AM
Re: (scorp508)
Quote:
Stock ones with loctite.
:iagree: :yesnod:
Feb 3, 2004 | 01:31 PM
Re: (Irish Mike)
thanks guys! Stock it is!
will the bolts be safe to reuse? or should I replace?
Feb 3, 2004 | 01:45 PM
Re: (bogus)
New dedicated bolts come with a yellow, thread locker on them. As I said, initially, this is NOT a high stress item. They are not going to break, if they stay put. The old bolts with a little LocTite will be more than sufficient. You just don't want them backing out. Good luck, and...
RACE ON!!!
Feb 3, 2004 | 01:50 PM
Just hit the old ones on a bench grinder w/wire wheel and you'll be good to go.
Feb 3, 2004 | 09:21 PM
Re: (scorp508)
sounds good to me, guys!
So... loctite it is!
Thanks!
I will update the thread on Sunday after all is done!
Feb 9, 2004 | 08:44 AM
Re: (bogus)
ok! All done!
The job is rather extensive, but, all in all, not very hard. It's remove/replace easy, really.
It just looks scary, cause so much has been removed...
Spring removal is a piece of cake with a floor jack! Just compress the one side and let it fall gently. Not a problem. Install is the same way.
I replaced my rear spring with a used one. I will post a pic of my original spring here shortly, but it was badly delaminated.
The new spring rides much better. Less giggles and such.
The Ujoints were worn, but only one, left inner, was really bad.
And after 123k miles, the bushings are crap... future project... tear the entire rear suspension out and replace EVERYTHING...
Thanks for everyones help! :cheers: :cheers: :cheers:
