Drive Shaft Question?
Old Feb 3, 2004 | 08:33 AM
CG77VETTE's Avatar
CG77VETTE
Default Drive Shaft Question?
All of the shop manuals instruct you to remove the entire exhaust system in order to remove the drive shaft. Is this really necessary? It looks like I can get away with only removing the cat and rear "Y". Thanks for any help.
Old Feb 3, 2004 | 09:45 AM
okinawa86vette's Avatar
okinawa86vette
Default Re: Drive Shaft Question? (CG77VETTE)
You should be able to get away with just that. Last time I had the driveshaft out, I didn't have to pull down the mufflers or front Y.
Chris
Old Feb 3, 2004 | 11:36 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Drive Shaft Question? (okinawa86vette)
:thumbs:
Old Feb 3, 2004 | 11:47 AM
scorp508's Avatar
scorp508
Default Re: Drive Shaft Question? (vinnies87)
I drop mine from the cat back to the mufflers just becuase it is so damn easy to remove as one large piece. :yesnod: Takes all of 3 minutes.
To Drive Shaft Question?
