Question regarding modifying compression ratio after the fact...
Old Feb 3, 2004 | 01:09 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Default Question regarding modifying compression ratio after the fact...
Perhaps I should be asking this in the Forced Induction section but is there any way to bring the compession ratio down to the 9:x level from the 10.x level by modifying the heads alone? I guess what I'm asking is if one were to build a new engine to initially run naturally aspirated (but with a bottom end that could withstand supercharging) with the intent of supercharging it at a later date, do you have to replace the pistons to get the CR down to a safe enough level to run the supercharger or can you somehow modify just the heads to get the CR down to an acceptable level? Thanks....
Old Feb 3, 2004 | 01:29 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Question regarding modifying compression ratio after the fact... (tobijohn)
A lot depends on how you build it initally. You can always use thicker head gaskets to lower the compression ratio, but that will screw up your carefully (hopefully) executed quench area, actually increasing the chances of detonation. The bast way to increase the volume of a combustion chamber is to unshroud the valves, out to the edges of the bore. For more, you may be able to remove material adjacent to the spark plug. Depending on how large an adjustment, you intend to make in the future, careful planning now, will make it easier, later. Good luck, and...
RACE ON!!!
Old Feb 3, 2004 | 02:39 PM
torquejunky's Avatar
torquejunky
You will need two sets of heads to do this. AFR heads for LTx motors can be purchased with 74 cc combustion chambers. You could easily switch between the AFR heads and your stock GM heads to make a change of approximately 2 points in compression ratio. Uing flat top pistons with 4 valve reliefs and 0 decked block will give approximately 11:1 with the GM heads and 9:1 with AFR 74 cc chamber heads. This makes it easy to switch between NA and supercharged. You really should use two different cams as well. The pistons and ring package should be set up for supercharging/nitrous - the ring lands should be located further from the piston top and ring gaps set wider. This won't be optimum for NA but is needed for a strong supercharged application.
Edit: This assumes 350 cu.in bored .030. If you don't care about switching back to NA you could build it with your stock heads and then have the chamber enlarged but you can only change compression ratio by about 1 point this way. Maybe start with 10.25:1 and then go down to 9.25:1. You might want slightly higher CR if going low boost (but why bother) or slightly lower if going very high boost, but the spread will still be about 1 point.
[Modified by torquejunky, 1:46 PM 2/3/2004]
Old Feb 4, 2004 | 12:27 AM
tobijohn's Avatar
tobijohn
Bench Racer
Default Re: Question regarding modifying compression ratio after the fact... (torquejunky)
...The pistons and ring package should be set up for supercharging/nitrous - the ring lands should be located further from the piston top and ring gaps set wider. This won't be optimum for NA but is needed for a strong supercharged application.
Thanks! When you say that this setup wouldn't be optimal for NA, where exactly would that show itself?
Old Feb 4, 2004 | 12:45 PM
Curveit's Avatar
Curveit
I agree with EFI-CFI...unshrouding the valves in the chamber would be the best. He forgot to mention that this might also increase power power at the same time, due to increased air flow around the valves. I trust you already have forged pistons; if not, that would be the way to go. The type of pistons would depend on expected boost levels.
:chevy
Old Feb 4, 2004 | 01:00 PM
tobijohn's Avatar
tobijohn
Bench Racer
Default Re: Question regarding modifying compression ratio after the fact... (Curveit)
The bottom end would definitely utilize components in anticipation of eventual supercharging (i.e forged pistons, forged crank, etc) . From what I've read, for pump gas (this would be a street/daily driver application) 10.5 CR is fine for NA and 8-8.5 CR is what you'd want for a SC running enough boost to make it worthwhile. I was just trying to find out if the buildup could be done in stages and to avoid pulling the NA engine once it's in the car. It looks like with proper planning, this can be done. Thanks to all for the feedback...
Old Feb 4, 2004 | 02:36 PM
torquejunky
It's really a very minor difference as far as power goes. The optimum piston/ring for normally aspirated would be lighter (the piston crown doesn't need to be as thick) with the rings located higher on the piston. This reduces the space above the piston ring but below the top of the piston that is somewhat dead air as far as the combustion process goes and can be a source of detonation. If building a stroker it can also allow a longer connecting rod without special rail supports for the rings. You can also use slightly thinner rings if going normally aspirated for reduced friction. Ring gaps should be tighter as the rings won't run as hot (while NA) and therefore won't expand as much.
For the supercharger the rings need to be located further down the piston to reduce heat in the rings. The piston crown needs to be thicker to handle higher temperature and pressure. Ring gaps should be larger to compensate for increased expansion from higher temperatures.
The supercharger piston/ring will work fine normally aspirated as these are all fairly minor differences in regard to power. It would have slightly higher ring leakage when run normally aspirated and slightly higher friction.
To Question regarding modifying compression ratio after the fact...
