stacking bins question
Old Feb 3, 2004 | 05:19 PM
SBNova's Avatar
SBNova
Default stacking bins question
I am using a 165 ECM and a 6E bin, that should be 16k. Now I understand that the factory prom is a 128. I read somewhere that I need to double the bin or program it to the last half for it to work for a 27C256. I doubled it, and burned it. I forget the software I used to double it, but then I tried the bin stacker in tunerpro. I selected 16k as file size, 256 as chip size and 16k as the block size and it gives me 16 spaces to fill with bin files! I know the math adds up to 256k, but I figured it was an apples to oranges thing since the factory bin is 16k on a 128 chip. Can someone set me straight??
Old Feb 3, 2004 | 07:42 PM
Black87c4's Avatar
Black87c4
Default Re: stacking bins question (SBNova)
dos copy: copy /b xx.bin + xx.bin yy.bin
Old Feb 3, 2004 | 10:04 PM
SBNova's Avatar
SBNova
Default Re: stacking bins question (Black87c4)
thanks, but I'm not using dos, Im in windows. I gather from your answer that there is in fact two 16k files per 256 chip?
Old Feb 3, 2004 | 10:23 PM
Black87c4's Avatar
Black87c4
Well you can get a dos prompt with windows, even XP
Old Feb 3, 2004 | 10:54 PM
Bluevette85's Avatar
Bluevette85
The 256 chip holds 256k bits of information. 1 byte = 8 bits.
Your bin is 16k bytes so the 256 chip holds two 16k bins (16x2x8=256)
In Tunerpro, set the bin size to 16k and chip size to 32k (32x8=256) and it will work.
Old Feb 4, 2004 | 06:27 AM
SBNova's Avatar
SBNova
Thanks! NOW I understand :yesnod:
To stacking bins question
