Fuel Injectors
Old Feb 3, 2004 | 06:06 PM
8835thL98's Avatar
8835thL98
Default Fuel Injectors
What all is required to install new fuel injectors??? I had my car in the shop and they wanted about 800 bucks for new ones and installation! I thought it sounded a little bit high, but is that about right??? Thanks in advance
http://www.corvette.racenet.net/induction.php
These are 24lbs. injectors and their only 230, how long will this take me at home??
[Modified by -=Persephone=-, 5:08 PM 2/3/2004]
Old Feb 3, 2004 | 06:12 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Fuel Injectors (-=Persephone=-)
Depends on your wrench ability and if you've ever had the top off... First time took me about 5 hrs complete.. thats with pictures, documentation, etc... i took my time... :cheers:
Old Feb 3, 2004 | 06:13 PM
SPEED750's Avatar
SPEED750
http://slponline.com/view_product.as...&SHOWEMAIL=Off
Check out this link. Smoke'n deal. The L98 is harder than most, but with the help of the forum, I would try it and save yourself BIG BUCKS.
Old Feb 3, 2004 | 06:22 PM
8835thL98's Avatar
8835thL98
Default Re: Fuel Injectors (SPEED750)
SPEED750: are those reliable?? What makes the shop charge so much more other than wrench time??
Old Feb 3, 2004 | 06:33 PM
vinnies87's Avatar
vinnies87
They say GM/Borsh type... if they are , thats a great price for new one. :thumbs:
Old Feb 3, 2004 | 06:44 PM
8835thL98's Avatar
8835thL98
Default Re: Fuel Injectors (vinnies87)
would those slp 25lb ones fit??
Old Feb 3, 2004 | 07:29 PM
8835thL98's Avatar
8835thL98
ttt
Old Feb 3, 2004 | 07:35 PM
neverendingproject's Avatar
neverendingproject
someone just installed these on their 91/L98. see if you can find it. in a nutshell , the only problem is you can use the locks on the injectors. no other problems.
Old Feb 3, 2004 | 11:40 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Default Re: Fuel Injectors (neverendingproject)
Dark Halo did. Here's the thread:
http://forums.corvetteforum.com/zerothread?id=743450
To Fuel Injectors
