Display blackout on 85
Old Feb 3, 2004 | 09:53 PM
Southern Comfort's Avatar
Southern Comfort
Default Display blackout on 85
tonight my display went black and the bright indicator and the turn signals lit up. after a second or two they went back to normal. Happened twice.
Any ideas or fixes in mind? :confused:
Old Feb 3, 2004 | 10:20 PM
SBNova's Avatar
SBNova
Default Re: Display blackout on 85 (Southern Comfort)
What happened to your bight ind and turn signals indicates a bad ground.
Old Feb 3, 2004 | 10:55 PM
D_C71's Avatar
D_C71
Default Re: Display blackout on 85 (SBNova)
I agree with above as a possible cause. Could also be cracked conductor on the Circuit Board (happened on mine, was able to Spot it and Solder fixed it.)
Lots of other potential failures/intermittants. Eventually, I had to send mine out for refurbishing. Over time, heat/cold cycling and vibration takes its tole.
I have the Factory Service Manual (85 Corvette) and bought a copy of Gordon Killebrew's "'84-'89" Corvette Digital Cluster" Manual. Still, mine eventually needed that refresh.
Old Feb 3, 2004 | 11:20 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Should be nothing new to you.... you do well in the dark.... :lol: :lol: Hey Steve hows it going... :thumbs:
Old Feb 3, 2004 | 11:45 PM
Southern Comfort
Default Re: Display blackout on 85 (vinnies87)
good vinnie....just hanging in there...you back on the job?
To Display blackout on 85
