LT4 HotCam Shift Points?
Old Feb 4, 2004 | 12:55 PM
Hi-psi's Avatar
Hi-psi
Default LT4 HotCam Shift Points?
Guys,
Here's the info, stock LT1 crate motor, LT4 HotCam, Crane 1.6RR's, K&N, MSD 6A, NGK's, Taylor wires, Hooker LT's, B&B TriFlo cat-back, 6spd.
What should I be shifting her at?
Old Feb 4, 2004 | 03:31 PM
93 ragtop's Avatar
93 ragtop
Default Re: LT4 HotCam Shift Points? (Hi-psi)
IMO you need stronger springs to go any higher then the 5800 rpm redline of the LT1. The LT4 has stronger springs and it has lighter valves. So to raise the redline you need springs.
Old Feb 4, 2004 | 03:55 PM
Hi-psi's Avatar
Hi-psi
Default Re: LT4 HotCam Shift Points? (93 ragtop)
Maybe I should have specified the car has the HotCam "Kit", not just the cam installed. So it has the beefier springs.
Old Feb 4, 2004 | 04:10 PM
Hi-psi's Avatar
Hi-psi
After roaming around over on CamaroZ28.com , it seems all the F-body guys with stock heads are shifting between 6300-6500. One guy posted a dyno chart showing the cam was still making constant power and not falling off up to about 6700-6800. Thoughts?
96GS#007's Avatar
96GS#007
6400
FWIW, I shift mine at 6600 (and sometimes 6800 :D) but I have the lighter LT4 valves and swapped to Crane valve springs (~120# closed / ~340# open). On the dyno my hp peak is at 6400.
Old Feb 4, 2004 | 04:49 PM
RichS's Avatar
RichS
Default Re: LT4 HotCam Shift Points? (96GS#007)
I shifted at 6300 with best results.
Old Feb 4, 2004 | 04:53 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Don't go above 6200 with the stock LT1 the bottom end can't take it.
http://vette.ohioracing.com/majmods.html
Gee what's that knocking noise?. The motor blew right at the finish line of an autocross event in the middle of nowhere Michigan. Of course right at the height of race season and one day after I had just spent big bucks on 4.09 gears. I broke my vette and Al Murrel, a fellow competitor, hauled me home. Thanks Al! You have an invitation to co-drive my car! Also, I owe thanks to John & Debbie Fessler, and Paul Wines for hauling my tire trailer home.
A word of warning, 6200 RPM is the Limit for a stock LT1. I set my rev limiter to 6400 RPM against the advice of Justin Vandersall (Superman Vette Mechanic). The motor lasted for maybe 10 revs at that limit. The LT1 rod caps can not take high RPMs. The cap on the number six cylinder stretched. The piston began to slap against the head when down revving. As soon as the engine cooled the bearing spun.
That's one of the reasons I'm holding off on the hotcam.
Old Feb 4, 2004 | 07:35 PM
96GS#007's Avatar
96GS#007
Default Re: LT4 HotCam Shift Points? (BrianCunningham)
Very interesting when one considers that the LT1 ('92-'96) and '96 LT4 connecting rods/caps/bearings are the same p/n. This is according to my GM microfiche and a pretty good book entitled "How to Rebuild Small-Block Chevy LT1/LT4 Engines" by Mike Mavrigian. The GM fuel cutoff for the LT4 is 6400rpm so assuming both references are correct, one wouldn't think GM would purposely exceed what they would surely know is a limit.
I've always heard the LT1 is limited to 6100 due to valvetrain stability (with original springs/valves/etc vs the original poster's LT4 springs). Once one gets past the valvetrain issue, 6400rpm is the limit for '92-'95 LT1s due to piston ring flutter. Dan Parker did some research and the '96 LT1s have the same piston rings as the LT4. The later rings have twist to promote sealing at high rpms.
FWIW :)
Old Feb 4, 2004 | 10:54 PM
BrianCunningham
I know a couple of guys who have spun rod bearings.
are the rod bolts the same?
I've heard that's why the caps stretch.
[Modified by BrianCunningham, 10:56 PM 2/4/2004]
Old Feb 4, 2004 | 11:02 PM
96GS#007's Avatar
96GS#007
The GM fiche have the rod & cap listed together as an assembly (if I recall they're cracked caps, so that would make sense). However, I thought the same thing as you about the bolts. So far I've been unable to locate a separate listing for rod bolts. If I find something I'll definitely post it.
Maybe the over-the-counter GM replacement parts are identical but factory installed pieces aren't?
Old Feb 4, 2004 | 11:20 PM
BrianCunningham
replacement vs original makes sense.
GM puts LT4 rods in thier crate motors, so that makes a lot of sense.
Need to find out what the original part #'s were.
Old Feb 5, 2004 | 12:08 AM
BrianCunningham
http://www.automotiverebuilder.com/ar/ar99928.htm
RODS
350 - The original LT1 came with regular forged 350 rods, that were shot peened for localized hardness under the head of the bolt and nut. Powdered metal rods were phased in for the Corvette around 1994 and used in all of the LT1 engines by 1995. GM made the change because the powdered metal rods were cheaper to make and were much stronger than the GM high performance "pink" rods. In fact, they are supposed to be good for up to 450 hp. They are machined at the parting line so they can be reconditioned.
http://www.grandsportregistry.com/lt1vslt4.htm
SPECIALLY MACHINED CRANKSHAFT
The crank itself was improved via something called undercutting and rolling. Undercutting is the machining of a groove into the corner of a journal. Though this would seem to weaken the crank at that point, it actually makes it stronger where tensile stress is most likely to cause sudden failure. Rolling the undercut introduces compressive stress to the area. This makes it more durable, because potentially catastrophic tensile stress generated during high RPM operation must first overcome the compressive stress before that area of the crank is subjected to tension. Undercutting, a groove cut into the corner of a journal, looks counterintuitive, but makes a crankshaft stronger where tensile stress is most likely to cause failure. By undercutting and then rolling it, compressive stress is introduced. Tensile stress during high-speed operation first has to overcome the compressive stress before there's any tension on the joint. And as tensile stress is what breaks crankshafts, undercutting and rolling make the crankshaft stronger.
DUAL-MASS FRONT TORSIONAL DAMPER
Tuned for high engine speed, also helps reduce stress on the crankshaft. LT1 pt.# 10128489 and LT4 pt.# 12551486
NODULAR IRON MAIN BEARING CAPS
These LT4 components are considerably stronger than their LT1 counterparts and resist failure at higher RPM's.
TEFLON REAR CRANK SEAL
Offers improved durability over the standard LT1 crank seal.
Wish I knew about the seal when I did mine! :crazy:
Old Feb 5, 2004 | 01:17 AM
zelement's Avatar
zelement
HOT cam makes there peak hp at 6300rpm.
I had my shift light set at 6300rpm.
Old Feb 5, 2004 | 05:28 AM
93 ragtop's Avatar
93 ragtop
I still believe it would be worthwhile to consider a different spring if you are going to rev to 6300 rpm. The LT4 may be able to do it with its lighter valves, but the LT1 valve would be better suited to a stronger spring. Springs are not that expensive, and a lot of damage could occur if it is too weak.
Old Feb 5, 2004 | 08:58 AM
96GS#007's Avatar
96GS#007
Did some more digging thru the fiche last night. The rod bolts are the same p/n for the LT1 ('92-'96) & LT4.
No proof, but I buy in to the theory that the over-the-counter parts are LT4 (whether LT1 or LT4). Those that have had problems with rods and bearings, likely experienced them with pre-'94 original LT1 parts.
Old Feb 5, 2004 | 08:53 PM
Third Gear's Avatar
Third Gear
:D That's why I decided not to do just a "Heads and Cam" on my 93. I'm gonna do it once, and do it right. :cheers:
To LT4 HotCam Shift Points?
