Help / inside lights wont turn off, system light flashing.
The only way to stop them or turn off is pull fuse. I took the light timer out from inside dash, (unpluged it) inside lights stay on, and system light just keeps flashing till fuse is pulled.
All of this started when i replaced my brake booster, I must have pulled somethin loose. I have the dash apart, top, right side, left, and center.
book says timer controls lights, if they stay on replace, but what about the system light flashing ? would door switches make light flash ? And how do the front door switches come out ? :cuss :banghead: :mad
