Question on AFPR setting???
Old Feb 6, 2004 | 07:33 PM
nlstrand's Avatar
nlstrand
Default Question on AFPR setting???
Restoring our 95 LT1 corvette and upgraded to 28 pound injectors. Purchased an Aeromotive adjustable fuel pressure regulator from Summit. This is probably an obvious question, but what do I set the AFPR at (28#)?
Thanks! :hurray:
[Modified by nlstrand, 12:47 AM 2/7/2004]
Old Feb 6, 2004 | 08:47 PM
nlstrand's Avatar
nlstrand
Default Re: Question on AFPR setting??? (nlstrand)
Any ideas?
Also, the fuel gauge on display always shows empty despite having full tank of gas. Where should I troubleshoot?
:banghead:
Old Feb 6, 2004 | 08:53 PM
1990CORVETTE's Avatar
1990CORVETTE
not sure but 44 to 46,,, somewhere in there :confused:
Old Feb 6, 2004 | 08:54 PM
VB Black Ice's Avatar
VB Black Ice
Default Re: Question on AFPR setting??? (1990CORVETTE)
Stock setting for our cars is 40#. setting it to 26# will do nothing but choke out the engine. According to TPiS ~45# is what you'd want
Old Feb 6, 2004 | 08:59 PM
nlstrand's Avatar
nlstrand
Thanks,
I'll try the AFPR around 45# for 28#injectors. :party:
Old Feb 6, 2004 | 09:06 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Measure our current fuel pressure and, assuming you have 24lb/hr injectors set the pressure to SQRT(24/28) * (current pressure). That assumes the both injectors are rated at the same pressure.
Old Feb 6, 2004 | 09:17 PM
nlstrand's Avatar
nlstrand
Hmmm,
Threw out stock injectors (24 or 26 pound?) as two were malfunctioning. Decided to buy and have installed new 28# injectors and threw the stock fuel pressure regulator for Aeromotive replacement as hoping to do future upgrades. Still have old injectors and regulator. What can I expect (any problems) with these new injectors in terms of performance? Will set AFPR at 44-46# and hope all is well! :confused:
Old Feb 7, 2004 | 01:46 AM
corvette1990's Avatar
corvette1990
Let me tell you my story of runnin rich. You might be able to smell it at tail pipe. Car will bog down alot. And worst of all, you will burn up the catylitic convertor, so that you will not pass emmisiions inspection. I wish I had tuned mine with an air fuel meter, before I started loosin money on parts. (it was a new cat too). The opposite is what I saw at the dyno shop in Virginia off I-95. A guy self tuned his car at the track for the fastest times in the quarter. He leaned it out so far, that he burnt a piston, and then had a dead motor. But he was quick that short day, I am sure. You are also measuring the pressure with the rubber vacum hose unplugged to the AFPR, and the vacumn leak plugged. This simulates Wide-Open-Throttle position. Some use the pressure guage with a hose and duct tape the gauge to the windshield, to see rear WOT pressure. Hope that isnt confusing enough.
Old Feb 7, 2004 | 05:02 AM
abtanner's Avatar
abtanner
Q:1, What pressure adj./setting for the (new)28#injectors.
A: Your stock units are 22#(Multi Tech). I suggest ya get the pressure settings from the party(s) that recommended/guided you to the higher flow-rated injectors and adustable fuel pressure regulator.
Q:2, Fuel quantity indicating zero (tank full).
A: Check for "open" circuit from dash to fuel tank terminal.If this cks. OK,replace "sending" unit (inside Tank).
BTW,I replaced my cloged/stopped-up stock injectors with the oft recomended Ford 24#, keeping stock FPR.No mixture issues. She runs great/normal.
Old Feb 7, 2004 | 09:22 AM
1MoorTym's Avatar
1MoorTym
I don't know what size you had originally, you mentioned 24-26, but depending on your future plans, you may have bought too large an injector.
To adjust the AFPR start out with the stock pressure and then add a pound or so to make up for the larger injector. It all about spray pattern. Too many people buy larger injectors and then believe lowering the pressure will compensate for that. All that does is ruin the spray pattern.
Did you buy injectors rated at 43 psi ?
To Question on AFPR setting???
