Oil filter adapter conversion?
Old Feb 6, 2004 | 09:19 PM
kman0066's Avatar
kman0066
Default Oil filter adapter conversion?
Alright, the 7-qt. oil pan and my 93 LT1 oil filter are not cooperating. I thought it was good but it is a tight fit and it is leaking oil, so I want to convert to the earlier type of adapter which does not tuck into the block. What parts do I need for this? I looked on CorvetteCentral but the illustrations look a little confusing. Any part numbers or links would help.
Old Feb 7, 2004 | 11:06 PM
kman0066's Avatar
kman0066
Default Re: Oil filter adapter conversion? (kman0066)
Well, if anyone is interested, they key was to use an adapter from an '87 vette which I got at a chevy dealership, the stock gasket, (2)1 1/4 inch bolts, and a PF30 oil filter. It fits perfectly with the 7qt. pan and long-tubes I have. No more oil leak from the filter being pressed up against the pan.
Old Feb 8, 2004 | 11:38 PM
93Quasar's Avatar
93Quasar
Hmmm. I don't know what pan you are using. My Canton comes real close to the filter, but doesn't touch it. I can still slide my filter tool that goes onto the 3/8 drive ratchet onto the end of the filter. The tool rubs the pan though. I have another adapter laying around in my pile of parts but didn't know what filter to use. It would basically be the size to replace the filter adapter.
To Oil filter adapter conversion?
