Problems installing Hurst shifter.
Old Feb 7, 2004 | 01:45 PM
GS 163's Avatar
GS 163
Default Problems installing Hurst shifter.
Well, I was out there for 2 hours and I cant get the damn pin out. What did you guys do, and how hard was it to get out? Maybe I am doing something wrong. Any other tips would be appreciated also. :)
Old Feb 7, 2004 | 02:25 PM
STL94LT1's Avatar
STL94LT1
Default Re: Problems installing Hurst shifter. (GS 163)
I used a punch and a small hammer to tap my linkage pin out. Guess I was lucky, because many have had to literally beat theirs out. My advice would be to try a little harder to tap it out, don't remember hearing of anyone damaging their linkage by tapping too hard.
Also, there is a chance the pin was installed the opposite way. Has the trans ever been out of the car?
Old Feb 7, 2004 | 02:59 PM
RichS's Avatar
RichS
Default Re: Problems installing Hurst shifter. (STL94LT1)
I had to beat my pin pretty good to get it out.
Old Feb 7, 2004 | 04:02 PM
GS 163's Avatar
GS 163
Default Re: Problems installing Hurst shifter. (RichS)
Tranny Has never been out of the car. I was out there for another hour and the thing will not budge. I have the c clip off too. Should I worry about driving it with that off. I will probably try to get it to the shop on Monday to get it up in the air. Any other tips I should know about, please do tell. TIA. :cheers:
Old Feb 7, 2004 | 04:15 PM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
i just popped the c clip, used a small punch and it came right out....
Old Feb 7, 2004 | 06:10 PM
billyhay's Avatar
billyhay
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Problems installing Hurst shifter. (My 95)
Me too, guess I was lucky.
Old Feb 7, 2004 | 08:22 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
My tranny was out when I did mine.... so no help here
Old Feb 8, 2004 | 02:10 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
:iagree: Me too...
Old Feb 8, 2004 | 04:11 PM
Glasman66's Avatar
Glasman66
Drive it out with a punch and you favorite beater!
Old Feb 8, 2004 | 04:41 PM
silver & red CE's Avatar
silver & red CE
Default Re: Problems installing Hurst shifter. (Glasman66)
Time for the 3lb sledge?
Old Feb 8, 2004 | 04:47 PM
GS057's Avatar
GS057
2018 C6 of Year Finalist
Can you do all the install from inside the car or do you need a lift to get under it? How long does a instll take?
Old Feb 8, 2004 | 04:52 PM
Jeffvette's Avatar
Jeffvette
Default Re: Problems installing Hurst shifter. (meyre1)
You have to have access from the top, as well as the bottom. SO you drop the exhaust, and remove the center console.
Old Feb 8, 2004 | 04:53 PM
silver & red CE
I'd call it an advance DIY project. There's a write up in the tech section. You have to remove the exhaust (most folks do anyway), pull the consule apart etc. It's pretty involved, but worth it!
Eric
To Problems installing Hurst shifter.
