Flat Top Detonation...
Old Feb 8, 2004 | 07:01 PM
autotech's Avatar
autotech
Default Flat Top Detonation...
88 C4 L98 5.7 - I installed flat tops in my engine and it appears I have a severe case of detonation under load. Timing is at 6 degrees. Any Suggestions?
Old Feb 8, 2004 | 08:25 PM
JackDidley's Avatar
JackDidley
Default Re: Flat Top Detonation... (autotech)
Stock 58cc heads? Thats a lot of compression for the street. A big sloppy cam might bleed off some cylinder pressure. Or maybe someone could burn a chip with little or no advance. Good luck. :chevy
