Is it really neccessary....
Old Feb 9, 2004 | 12:30 AM
JJ 86's Avatar
JJ 86
Default Is it really neccessary....
to run colder plugs with a 100hp shot? What would happen if i were to spray with the stock heat range plugs?
Old Feb 9, 2004 | 08:38 AM
Baldturbofreak's Avatar
Baldturbofreak
Default Re: Is it really neccessary.... (JJ 86)
There is the possibility of detonation.
Old Feb 9, 2004 | 08:04 PM
Cartier1's Avatar
Cartier1
JJ86!
i´m going to run nitrous too,and i bought the TR6 plugs one heat range colder,and are too cheap :D :D
do you have pictures of your nitrous setup,cause i dont know exactly where to place it the nozzle for the hose form!! :confused:
Old Feb 9, 2004 | 10:31 PM
ANTI VENOM's Avatar
ANTI VENOM
Default Re: Is it really neccessary.... (Cartier1)
I ran a 150 shot on my L98 for years with the "stock" heat range plugs with no problems. There is alot to be said for tuning. I would retard the timing a bit to be on the safe side.
Old Feb 11, 2004 | 04:31 PM
Mo_Bandy's Avatar
Mo_Bandy
Default Re: Is it really neccessary.... (ANTI VENOM)
:iagree: it's kind of a trade off, colder range plugs or running with less timing....
Mo
Old Feb 12, 2004 | 12:20 PM
MasterDave's Avatar
MasterDave
Moderator
I run a 125 shot, no timing or spark plug change at all. Just check your plugs after a nitrous run.
Old Feb 13, 2004 | 08:36 PM
Pete K's Avatar
Pete K
Default Re: Is it really neccessary.... (MasterDave)
:iagree:
Old Feb 14, 2004 | 12:47 AM
Dan Parker '96's Avatar
Dan Parker '96
You may not melt your electrodes...
Let me know what happens.
To Is it really neccessary....
