Questions: TB Bypass, Plenum porting and air temp sensor
Old Feb 10, 2004 | 12:50 PM
brock71's Avatar
brock71
Default Questions: TB Bypass, Plenum porting and air temp sensor
I've got the upper plenum and soon the runners of the L98 off in preperation of either a new intake manifold gasket or just tightening up the manifold bolts (small coolant leak near the thermostat housing). With the plenum off, I took the liberty of begining the polsihing process (outside) which is looking REALLY nice. bit a few pits that still need more sanding. So now I need some ideas on what else to do while it's off.
I've already knocked down the egr blockers and smooth that area up as per the thirdgen.org site. I'm wonder if I should knife-edge/ round the dividers in the plenum that go to the runners? Other than that, I'm going to punch out the gasket a little and port the runners/plenum to match.
Next, I've already bypassed the throttle body and I'm getting ready to polish that up too, but I'm wondering about that lower plate. Do I even need that plate and sensor now that coolant no longer runs through it? I could make a block off plate if nothing bad comes from having that sensor unplugged.
Lastly, I want to move the air temp sensor on the bottom of the plenum. I'll splice and heat shrink to extend the wiring, but I'd like to know where you guys relocate that sensor to?
Here's the begining of the plenum polishing:
Here's the plenum porting...still need to clean it up a little, but the bulk of it is done.
Old Feb 10, 2004 | 01:33 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: Questions: TB Bypass, Plenum porting and air temp sensor (brock71)
Looks Good I know nothing about L98 tho
bump for ya :cool:
Old Feb 10, 2004 | 01:51 PM
jmrl98's Avatar
jmrl98
Default Re: Questions: TB Bypass, Plenum porting and air temp sensor (VictorRussell'92)
Nice job on thte porting. I may have gone a little too far on removing the EGR hump, but I know how to fix that. I also gasket-matched the plenum and runners, making the plenum-to-runner holes as large as possible. Some guys siamese the openings on the plenum and runners. Get a MAT relocation kit from any of the major catalog companies. The sensor gets relocated to the back of the air box, in front of the MAF sensor. The kit supplies the necessary equipment. It is a good mod, especially for throttle response and for enhancing future mods. :seeya
Old Feb 10, 2004 | 02:47 PM
brock71's Avatar
brock71
Default Re: Questions: TB Bypass, Plenum porting and air temp sensor (jmrl98)
Yeah, I'm seriously considering siamese'ing the plenum runner side, but leaving the base alone. I'll see if I can find a place to put that sensor before I go shelling out the $$$ for the kit. Thanks.
Does anyone really know about removing the lower coolant passage on the TB and covering with a block off plate??? It'd be sooo nice if I could ditch that thing.
[Modified by brock71, 7:49 PM 2/10/2004]
Old Feb 10, 2004 | 05:42 PM
brock71's Avatar
brock71
Here's the plenum all polished up.
Old Feb 10, 2004 | 06:32 PM
dwestsr's Avatar
dwestsr
If I read your post right, you want to do away with the sensor on the bottom and replace the lower plate with a flat plate?
NO CAN DO!!! That sensor is the Idle Air Control (IAC) sonenoid which the ECU used to control idle speed. Without it, your idle would not respond to changing loads IE, air conditioning etc. even if you could set it manually.
Old Feb 10, 2004 | 08:28 PM
brock71's Avatar
brock71
Default Re: Questions: TB Bypass, Plenum porting and air temp sensor (dwestsr)
Alright, cool. The IAC stays then.
Old Feb 10, 2004 | 09:15 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
I removed all of the excess metal around the iac I just kept three screw holes around if you look at the gasket you can see what you need to keep.It makes it easier to get to vacum lines under throttle body.also looks much cleaner.
Old Feb 10, 2004 | 09:23 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
There was a thread about a year ago on removing most of the lower plate.
There was a pic and a link I think.
By brain's not too good but I think it was oldman or grumpyvette. :confused: :crazy: :smash:
I'm going to try the search engine :crazy:
:cheers:
Old Feb 10, 2004 | 09:30 PM
AGENT 86's Avatar
AGENT 86
Default Re: Questions: TB Bypass, Plenum porting and air temp sensor (AGENT 86)
:cheers:
It was grumpvette, but I can't find it.
Do a search on topics by grumpyvette.
There was lots of knowledge in that guys brain :eek:
I miss him :smash:
:cheers:
To Questions: TB Bypass, Plenum porting and air temp sensor
