Piston clearance?
Old Feb 11, 2004 | 01:40 PM
dave_85's Avatar
dave_85
Default Piston clearance?
I got the heads off my 85. The cylinder walls look good. I can still see
the cross hatch and there is no ridge. I can get a .015 feeler gage
between the piston and the cylinder wall when the piston is about half way
down. :confused: Are pistons the same diameter at the skirt and at the top? Is it normal to have a gap between the top of the piston and the cylinder wall?
Old Feb 11, 2004 | 02:19 PM
speedjohnson's Avatar
speedjohnson
Default Re: Piston clearance? (dave_85)
These are usually measured 90 degrees to the pin. If they're forged pistons they aren't necessarily round when cold.
Old Feb 11, 2004 | 02:27 PM
dave_85's Avatar
dave_85
Default Re: Piston clearance? (speedjohnson)
:iagree: with the 90 degree to the pin.
Anyone ever measure the diameter at the top compared to 90 deg. to the pin?
Old Feb 11, 2004 | 07:41 PM
CFI-EFI's Avatar
CFI-EFI
The dimension you are checking is meaningless. The piston is measured at 90* to the pin, as mentioned, at approximently pin height. Usually the piston is miked, and the bore checked with a dial bore guage. I think your '85 has the same forged pistons as my '84. The "production clearence is, .0025" - .0035", with a "service max" of .0045". Cast pistons are clearenced, much tighter than this. It IS possible to verify from the top with feeler guages, but not with the rings installed. Good luck, and...
RACE ON!!!
Old Feb 12, 2004 | 08:28 AM
dave_85's Avatar
dave_85
Default Re: Piston clearance? (CFI-EFI)
OK. It just looked odd that I could see the top ring.
To Piston clearance?
