Gloss black engine components - absorb too much heat?
I'm considering painting the valve covers, plenum and runners gloss black. In doing so, will I absorb too much heat? It's either gloss black, or candy red.
Re: Gloss black engine components - absorb too much heat? (StephensblackL98)
if the engine is bathed in sunlight it will probably absorb more heat than it radiates. if not, it will actually radiate more heat than white. a perfect "black body" radiates energy proportionally to the 4th power of its temperature. anything less than a perfect black body will radiate something less than that.
Short answer - No, go for black if that's your first choice.
Technical answer - Black won't make much of a difference, especially on the aluminum components, which will heat up due to conduction. Black is only a factor when considering radiation heat transfer, which isn't the dominant heating mechanism here.
Black paint helps both heat emission and heat absorption. For power production the discussion should focus on the intake manifold and runners.
To answer this question, you just need to know whether the underhood air temp is higher or lower than the intake manifold temp. If it the underhood air temp is higher, paint it silver. If it is lower, paint it black.
Altho I haven't done it to the LT1, we have painted Ford and MOPAR drag engines flat black for years after the research shows a measurable increase in heat transfer with black. The comment about aluminum and the fact you are talking about a street engine probably means if you like gloss black, go for it, but you won't notice much of a difference.
Re: Gloss black engine components - absorb too much heat? (Mr6spd)
I'm missing your point. The difference in air temperature will drive the convective heat transfer and the color of the surfaces has no bearing. The color of surfaces will determine the radiative heat transfer, and the difference in temperatures between the manifold/runners and the underside of the hood is important.
From a convective standpoint, if you want to cool the intake/runners, then make sure the air under the hood is cooler. From a radiative standpoint, if you want to cool the intake/runners, paint them black (so that they emit) paint the underside of the hood black (so it absorbs) and make sure that the underside of the hood is at a lower temperature so that heat flows toward it.
Re: Gloss black engine components - absorb too much heat? (sraft)
Wow! Thanks, guys. I interpret all this as the bottom line is that I'm not going to see much difference with black components. Gloss black it is! Again, thanks for your time.
Paint thickness can be more inportant than color. Also gloss is a poorer rediator than flat. In the end, it won't make much difference on valve covers.
Re: Gloss black engine components - absorb too much heat? (xs650)
Black is what you need to release heat. Gloss black will retain more heat than flat. Light colors and shiny metals (chrome valve covers) reflect heat back into the engine.
Studies show black "releases" more heat. Keep in mind not to apply too much paint because you will in effect be "jacketing" the heat inwards. If thermal efficiency is your goal, apply one coat of black over the bare metal.
