LT4 - Rev Limiter
Old Feb 12, 2004 | 12:38 PM
rcolling's Avatar
rcolling
Default LT4 - Rev Limiter
At the track I have to shift into 3rd at the 1/8th just prior to the finish and into 4th at the 1/4 just prior to the finish.
I would like to try raising the rev limiter to get through that last 100 feet.
Anybody else done this?
Do you think 6700 would be OK?
Old Feb 12, 2004 | 01:31 PM
STL94LT1's Avatar
STL94LT1
Default Re: LT4 - Rev Limiter (rcolling)
You may want to change your valve springs before spinning your LT4 to 6700 rpms. Jim "96GS#007" Mason is running his LT4 to 6800 rpms, with upgraded valve springs. Maybe he will chime in on this thread.
Old Feb 12, 2004 | 02:23 PM
96GS#007's Avatar
96GS#007
6700 will be fine. Keep a close eye on your valve springs and consider them a "wear item" if you race a lot.
I just switched to Crane p/n 99845 H-11 Tool Steel Springs. I trashed a set of springs from Combination Motorsports in less than 6 months doing driving schools, open track sessions and auto-x's.
Old Feb 12, 2004 | 02:26 PM
all4c4lt4's Avatar
all4c4lt4
Default Re: LT4 - Rev Limiter (96GS#007)
What did you have to do to make those springs work? I assume they are not a drop in replacement.
Old Feb 12, 2004 | 04:07 PM
96GS#007's Avatar
96GS#007
Default Re: LT4 - Rev Limiter (all4c4lt4)
They actually turned out to be a drop-in. I was afraid the ID of the spring was going to be too small to clear the LT4 locator. In place of the LT4 spring seats I was going to run L98 seats. As it turned out the springs fit the LT4 seats. You'll need the appropriate retainers as well.
To LT4 - Rev Limiter
