Power-off PCM/ECM re-learn question
Old Feb 12, 2004 | 01:20 PM
Lone Ranger's Avatar
Lone Ranger
Default Power-off PCM/ECM re-learn question
When you cut power to the ECM/PCM and a re-learn is initiated next drive after power is restored, ar the fuel trim cells (BLM's) the only thing that gets re-learned?
Old Feb 12, 2004 | 01:59 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Power-off PCM/ECM re-learn question (Lone Ranger)
That's the way it works with OBD-I but not sure about OBD-II.
In fact I don't believe OBD-II can even be reset by disconnecting power to the ECM as it uses flash memory to store data instead of volatile RAM.
Old Feb 12, 2004 | 03:26 PM
Lone Ranger
Default Re: Power-off PCM/ECM re-learn question (65Z01)
:cool: My '95 is OBDI, just has the OBDII 16 pin ALDL socket :cheers:
Old Feb 12, 2004 | 04:13 PM
65Z01's Avatar
65Z01
Ah, in that case simply open the connector in the Or wire comming from the battery to the ECM for 1min. to reset the BLM cell values to nominal 128.
To Power-off PCM/ECM re-learn question
