Using the doug Nash 4+3 o/d without a computer
Old Feb 13, 2004 | 09:11 AM
vettework's Avatar
vettework
Default Using the doug Nash 4+3 o/d without a computer
Is their a way to use the 4speed and o/d unit in, say my 66 Impala.Is anyone familair with
its workings that some kind of switch or something.You tell me.
Frank
Old Feb 13, 2004 | 09:17 AM
NoWorries's Avatar
NoWorries
Default Re: Using the doug Nash 4+3 o/d without a computer (vettework)
I'm sure there is, although it wouldn't be an automatic OD anymore, it'd be manual. I don't have my schematics with me where I am, but I'm sure it's just a go/no go signal that locks the OD clutches. I'm sure someone will chime in with schematics.
:seeya
P.S. Unless you've got a free 4+3, I'd go with a different trans. :seeya
Old Feb 13, 2004 | 09:22 AM
ZylaRace's Avatar
ZylaRace
Default Re: Using the doug Nash 4+3 o/d without a computer (NoWorries)
The OD On/Off operates off of +12v or not. The circuits controls (relay) changed over the years, but it is still the same +12v or not. You could control it w/ a relay or a switch. But, like said,... it will be manual.
Old Feb 13, 2004 | 09:36 AM
vettework's Avatar
vettework
I had the makings of a 71 lt-1 350 aka a 010 hi nickle/ tin block, forged crank and 487 heads from a low mile 71 3/4 ton p/u for about 10 years, I gave it to my brother for his father/son 66 impala ,Last time I went over the car had no front on it and everything was rusted,So they gave me the car, and I got a free transmission from the guy next door,Is all rebuilt except the heads and the back part of the trans........so its ether get a t-10 tailshaft and housing or go for the overdrive.
Old Feb 13, 2004 | 10:16 AM
scorp508's Avatar
scorp508
Sure it can be done! All the ECM does is fire 12v out a certain pin to the O/D relay when there is an "O/D Request". This 12v goes to the relay which then enables to O/D solenoid inside the overdrive unit. When this happens as long as there is sufficient fluid pressure in the tranny the pressure switch holds the ground contact and O/D enables. If fluid pressure dropped below acceptable values (like when rolling to a stop) the pressure switch opens the ground and O/D would disengage on you.
To Using the doug Nash 4+3 o/d without a computer
