New member enjoying corvette forum very much, I have a problem I need help with.My 93 starts and runs fine cold, as soon as it reaches normal temperature it starts running very bad,feels like I'm puling a big trailer when I accelerate,misses,hesitates,backfires.I took it to dealer they said it was computer,still no change.I have a few mods,KN,160 thermo,hypertech,355 gears,no mufflers,60,000 miles.I'm thinking optispark,its original.Anybody have anyother ideas?
A clogged cat will cause problems the more it warms up to the point where the car almost has no power. Something to look into if it is not the computer.
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Has anyone had this problem? (Pete K)
Had similar symtoms on my 87 when maf sensor went bad.
:cheers: I am having similar problems now with my 88 and it seems to be in the MAFcircuit. Getting codes 33 & 34, but diagnostic tests say the Maf sensor itself is OK, ground is bad.
I replaced relays and now the problem is intermittent and the car runs great as long as it doesn't get an "intermittent"! When it does, it runs like limp home, but as soon as I clear the code, it runs great again
