ABS Light on, no codes.
Old Feb 17, 2004 | 07:46 PM
cash's90's Avatar
cash's90
Default Re: ABS Light on, no codes. (Chosen Won)
Your red buckle seat belt light is probably the dreaded SIR sensor corrosion problem unique to 1990 models. Look in the archives for the procedure to correct that problem. I corrected mine and it's not that difficult. I've had the same problem as you re the ABS and had a dealer look at it. The dealer gave me an estimate of "up to" $2,300 to trouble shoot and repair the problem. I just tend to drive a bit more cautiously.
Old Feb 18, 2004 | 08:22 PM
Chosen Won's Avatar
Chosen Won
Great news! For some reason, the ABS light went off today. I actually shut the car off while going down the interstate and turned it back on to make sure the light still worked. Sure enough, it stayed off, WHHOOOO HOOOO! :party:
Old Feb 18, 2004 | 10:40 PM
88_vette's Avatar
88_vette
Didn't read all the post but I had the same issue. The ABS light came on and wouldn't go out. Turned out to be a blown fuse. Check all your fuses and contacts.
