Fuel Pump Relay?
Old Feb 15, 2004 | 10:11 AM
Xssesive's Avatar
Xssesive
Default Fuel Pump Relay?
I know there is a relay that provides line pressure that comes on when the key is on, not working on my car. Trying to locate and figure out the problem, having to crank the car many times to start in the morning. Any help would be welcome. THX
Old Feb 15, 2004 | 10:34 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Fuel Pump Relay? (Xssesive)
If you do a search on Fuel Pumps, C4 Tech/performance, bodies, archives you'll get more info than you can imagine... good luck :lurk: :thumbs:
Old Feb 15, 2004 | 10:39 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Beside wiper motor on firewall
:cheers:
Old Feb 15, 2004 | 06:56 PM
Pete K's Avatar
Pete K
Default Re: Fuel Pump Relay? (vinnies87)
You may want to check and possibly replace the oil pressure sending unit. gm had a lot of problems with these. Your engine needs to see oil pressure to fire. If the unit is out of whack you will get long crank time. I have seen this 5 times on 5 different gm products and this was the fix. Hope this helps.
To Fuel Pump Relay?
