would you go with mini ram or ported tpi setup
Personally, I kept the TPI, went with the base, large runners ported plenum, etc., etc., etc.
I wanted to keep all the torque and improve the power because thats where I spent most of the time with the car - lower in the rpms, cruzin around.
If you see yourself high in the rpm range a lot then this won't work for you.
Its up to you. Do you want a lower RPM stump pulling torque monster that makes good horsepower, a high RPM horsepower monster that makes good torque or possible a medium ground of both?
I'll tell you right now that if you go miniram I'd suggest doing a whole lot more than just the upper end.
Personal preference is still the right answer so here is the bottom line: with the Big Mouth/runners you will have more torque down low (long runners make low rpm torque but breathing becomes an issue as rpm rises), and therefore your hp peak will be at a lower rpm - the downside is that you will definitely be limited as to how much hp you will make - probably by up to 60 hp based on my set-up (maybe even more). With the miniram/ZZ9 you have shorter runners (but longer than LT1) so the whole curve shifts up the rpm range - less torque down low, but higher rpm and therefore substantially more hp. And don't misunderstand the miniram/zz9 makes plenty of torque - just not down low.
Last point, if you do a miniram, change the cam or you are wasting your money. If you are absolutely staying with stock cam and un-ported small valve stock heads go with the Big Mouth/ runners
But the whole issue is irrelevant if you don't change that cam. In fact, IMHO a miniram setp-up with stock cam would probably run quite poorly!
If you want to push the power band upward a little right now with only a little low end loss for almost no $$ just port the plenum, upper runners and siamese the stock base. You can see the results in dyno pulls on my site. Now my shift point is around 5,600rpm and with heads, cam & headers it is predicted to pull to a little over 6k RPM for best ETs.
You could also begin to think of some mods to your A4. If you want to keep most of the stock feel, go with a 2,000rpm TC (yours is a 1,500rpm) and TransGo shift kit. The former will allow you to launch a little higher into the power band while the latter will make heavy throttle shifts a lot more fun.
If I were you, I wouldn't even consider a miniram unless you plan on doing ALOT more, as was previously stated. You're going to need to carefully match a cam, the heads ("garage porting" as they say, down the local shop ain't gonna cut it, you're going to need excellent CNC'd heads, and this job is terribly expensive) with that upper breathing intake. But now you'll be spinning big RPMs, and your bottom end will need upgraded as well. Are you sure you want to do this on your L98?
Scorp asked the perfect question. To stay in "safe" RPM range (upper 5,000's to maybe 6,000 at most when you shift your 6 speed in 1rst two or three gears), go all-out and port your TPI or better yet get some aftermarket parts and have them preofessionally ported to all match as a system....a little more expesive yes, but better gains there. For the L98, I would go full Supperram intake and get those '91 heads fully ported with 3 angle vavle job, the works.
Get a cam like the LPE 219/219. With this setup, you'll have all the power from off-idle on thru to upper 5,000 RPMs that you'll ever want on a street machine, it will feel like a super-amplified L98 that you love. Miniram? Thats more like a super-powered LT1, if you want that. Again, the "system cost" is much higher if you do that miniram thing. LPE did an ungodly great job with SR/219 cam/upgraded heads setup, I've heard about this from too many people now who have done it and know what they're talking about. What you'll be doing is screeching down the street going sideways the whole time:lol:
And this is what I've learned, today and everyday :D
Good luck! :cheers:
