stock injectors.
Old Feb 17, 2004 | 05:08 AM
devilfish's Avatar
devilfish
Default stock injectors.
How much can the stock injectors flow? Im amaing at 420-450 hp. I guess I need SVO #24 then right?
Old Feb 17, 2004 | 10:14 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: stock injectors. (devilfish)
No expert here, but from the reading on CF that sounds right... sure you'll get a motor head to confirm....
Old Feb 17, 2004 | 04:34 PM
vader86's Avatar
vader86
22lb injectors would probably fall off a bit under that power range, so I would go with the 24s.
Old Feb 17, 2004 | 04:50 PM
CarAteMyMoney's Avatar
CarAteMyMoney
I was told 22's should be fine up to 350-375 horse. I'll be using some sonic cleaned stockers on a motor good for about 370 at the crank with an AFPR and im told to expect great results, though 24's might be good too
Old Feb 17, 2004 | 05:05 PM
FD2BLK's Avatar
FD2BLK
Talk to Ski or Cork, I think they are both in the 500+ range with 24#s
Also do a search Ski did an extensive write up on this a while back
Old Feb 17, 2004 | 11:07 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
You will need 33lb injectors for that application. See http://www.megasquirt.info/index.htm
To stock injectors.
