Injector/Fuel Rail Question.
Old Feb 17, 2004 | 09:54 AM
jeepie91's Avatar
jeepie91
Default Injector/Fuel Rail Question.
I tried doing a search but didn't find an answer to my question so I am posting it:
I have a 91 auto and am removing my injectors for cleaning, I have the plenum off. My question is can I remove the fuel rail and injectors without removing the runners, it looks like there is enough room to do this, has anyone removed their injectors leaving the runners on ?
Thanks.
Old Feb 17, 2004 | 10:05 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: Injector/Fuel Rail Question. (jeepie91)
Iv'e read that you can by seperating the fuel rail and remove in banks of 4
:cheers:
Old Feb 17, 2004 | 10:06 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Injector/Fuel Rail Question. (AGENT 86)
:iagree: :yesnod:
Old Feb 17, 2004 | 10:30 AM
scorp508's Avatar
scorp508
Default Re: Injector/Fuel Rail Question. (vinnies87)
There are 4 torx screws that hold the crossover tubes into the rails. Remove those and you can pull the rails apart. There are o-rings on each end of the crossovers. Make sure you coat them with motor oil when you reinstall to make sure they slide in nicely and don't bind.
Old Feb 17, 2004 | 11:06 AM
jeepie91's Avatar
jeepie91
Thanks for the info, can I remove the runners without removing the valve covers ? Do you think it would be better to remove the runners then the entire fuel rail ?
Old Feb 17, 2004 | 11:12 AM
scorp508's Avatar
scorp508
Its been so long I can't remember if you can get at the lower bolts with the valve covers on or not. I am pretty sure that you can't.
Old Feb 17, 2004 | 11:49 AM
TA's Avatar
TA
[QUOTE] can I remove the runners without removing the valve covers ?/QUOTE]
I think you can, but if I call correctly it was very difficult to get at the bottom bolts :yesnod:
Old Feb 17, 2004 | 09:30 PM
69vetteracer's Avatar
69vetteracer
Yes you can. Done it many times. :chevy
Old Feb 17, 2004 | 11:17 PM
88_vette's Avatar
88_vette
Default Re: Injector/Fuel Rail Question. (69vetteracer)
I would suggest taking the fuel rail off in one peice. Unless you want to re-do the seals and what not. Not a bad idea with the age, but also they say don't fix it if it's not broke. I think the stock runners can be taken off with a long torx bit. I bought a long alen head wrench that fit the torx, then cut the "L"/curve part off and put a socket on the end. Worked like a champ
[Modified by 88_vette, 11:12 PM 2/17/2004]
Old Feb 17, 2004 | 11:47 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Default Re: Injector/Fuel Rail Question. (88_vette)
I removed the runner with valve covers on i found the perfect tool for the lower bolts .My extra roof tool the torx bit on the top tool is the same as the runner bolts.I used that and a 1/4 drive ratchet with a short extension.
Old Feb 18, 2004 | 02:27 AM
cash's90's Avatar
cash's90
Default Re: Injector/Fuel Rail Question. (crash1mac)
With my runners in place, I removed the fuel rail assembly by separating just the left rail first. No need to separate both rails from the cross pieces.
Old Feb 18, 2004 | 10:38 AM
jeepie91's Avatar
jeepie91
Thanks for the help. I was able to get at the bottom runner bolts with the valve cover on, so I am planning on taking the runnners off , since some of bolts were not that tight. that way I can install new gaskets and make sure everything is torqued properly.
Thanks again.
[Modified by jeepie91, 10:39 AM 2/18/2004]
Old Feb 18, 2004 | 01:38 PM
TA's Avatar
TA
Thanks again.
Be sure to remember the runner bolt that threads from the inside (from intake). Its easy to miss that one if your not looking for it.
To Injector/Fuel Rail Question.
