Help-Low temps
Old Feb 17, 2004 | 10:20 AM
Batvetteman's Avatar
Batvetteman
Default Help-Low temps
Drove the Vette to work today. Temp gauge (water and oil) never got above 120. I did have some heat in the car. Sound like the thermostat stuck open? :confused:
Old Feb 17, 2004 | 11:06 AM
GS919's Avatar
GS919
Default Re: Help-Low temps (Batvetteman)
That is where I would look. :cheers:
Old Feb 17, 2004 | 01:16 PM
CFI-EFI's Avatar
CFI-EFI
How far is it to work? How cold was it outside? It certainly could be a thermostat that didn't close, but I think it's more than that. First, it would have to be a fairly quick trip to keep the temps under 120, and/or awfully cold out. And second, 120 would generate very little, if any, heat from the heater. I think there is a guage problem AND a stat problem. Good luck, and...
RACE ON!!!
Old Feb 17, 2004 | 01:32 PM
Batvetteman
Default Re: Help-Low temps (CFI-EFI)
About 1/2 hour ride to work on interstate. Temp outside was about 14 degrees. Your right, there was very little heat! I don't think its a guage problem, they seemed to work fine last summer. Hopefully the t-stat is at fault. Maybe someone installed a 160 stat.
Old Feb 17, 2004 | 08:02 PM
CFI-EFI's Avatar
CFI-EFI
A 160 stat does provide VERY little heat from the heater. A half hour of interstate driving would be more than plenty to get to 160*. I'd start with the stat, and see how things look from there. *I* would reccommend nothing lower than a 180. Good luck, and...
RACE ON!!!
Old Feb 18, 2004 | 09:50 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
RACE ON!!!
:iagree: :thumbs:
To Help-Low temps
