Supercharged engine with a miss.
Old Feb 17, 2004 | 08:17 PM
Allblownup's Avatar
Allblownup
Default Supercharged engine with a miss.
I have a miss at idle and it will smooth out every once and a while for a short time. I will punch it at idle and have a back fire. Under load it misses and makes no power. I have changed the plugs and wires. Do not know were to try next. Any help would be appreciated.
Old Feb 17, 2004 | 08:32 PM
Pete K's Avatar
Pete K
Default Re: Supercharged engine with a miss. (Allblownup)
One of my tricks for this is to spray water from a squirt bottle on each header tube, one at a time, with engine warmed up and running. The cylinder with the miss will not fizz as much as the others. This only works on a dead miss not one that floats. Hope this helps :thumbs:
